• DeepStream Version
• TensorRT Version
I am currently working with tlt-converter and deepstream and was hoping you can provide insight into model encryption and decryption. Currently, tlt-converter requires the key to be passed through the command line; on the other hand, allowing deepstream to compile the model requires without tlt-converter requires the key to be in plain text within the pgie.txt file. Is there a way we can override this behavior so that all the command line arguments are never in plain text or viewable from logs? If not, is there somewhere I can look in order to get an idea of the tlt-converter source code so we can implement the same thing?
Any insight into this is much appreciated as model security is crucial and storing the key as an environment variable, passing it through the command line, or leaving it in plain text in the pgie.txt is counterproductive to the whole idea of encryption.
