GPU
• DeepStream Version
Deepstream 5.1
• TensorRT Version
TensorRT 7.2
Driver Version 515
Bugs
I have a problem while running Deepstream and reading video source from camera. Currently I’m running Deepstream 5.1 in Docker and when camera stream disconnects for some seconds Deepstream crashes aswell. Error from docker:
ERROR from source: Internal Server Error
Debug info: gstsouphttpsrc.c(1433): gst_soup_http_src_parse_status (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstSoupHTTPSrc:source:
Internal Server Error (500), URL: http://192.168.16.204:8000/camera/mjpeg, Redirect to: (NULL)
ERROR from source: Internal data stream error.
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstSoupHTTPSrc:source:
streaming stopped, reason error (-5)
ERROR from typefindelement0: Stream doesn't contain enough data.
Debug info: gsttypefindelement.c(996): gst_type_find_element_chain_do_typefinding (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstTypeFindElement:typefindelement0:
Can't typefind stream
Quitting
App run failed
My config.txt:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=30
[tiled-display]
enable=0
rows=1
columns=1
width=640
height=480
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
type=2
uri=http://192.168.16.204:8000/camera/mjpeg
num-sources=1
gpu-id=0
cudadec-memtype=0
roi=782:290:328:317
[sink0]
enable=1
type=1
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=1
[osd]
enable=1
gpu-id=0
border-width=2
text-size=20
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Serif
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
nvbuf-memory-type=0
[streammux]
gpu-id=0
live-source=0
batch-size=1
batched-push-timeout=40000
width=416
height=416
enable-padding=0
nvbuf-memory-type=0
[primary-gie]
enable=1
gpu-id=0
batch-size=1
gie-unique-id=1
process-mode=1
nvbuf-memory-type=0
config-file=config_infer_primary.txt
[secondary-gie0]
enable=1
process-mode=2
gpu-id=0
batch-size=1
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_picklist.txt
As you can notice I’m reading video source as:
type=2
I have also tried the same thing with USB camera and disconnecting it from my computer, deepstream crashes the same way.
My question is - are there any settings that I could set in config.txt that would try reconnecting to video stream and deepstream wouldn’t exit?
