Deepstream failed when using TLT model as pgie
• Hardware Platform (Jetson / GPU) = dGPU
• DeepStream Version = 5.0
• TensorRT Version = 7
**• NVIDIA GPU Driver Version (valid for GPU only) = 450.36.06 **
I used peoplenet model (https://ngc.nvidia.com/catalog/models/nvidia:tlt_peoplenet) as pgie for deepstream_infer_tensor_meta_test.cpp
The config file for pgie is below
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
tlt-model-key=tlt_encode
tlt-encoded-model=/opt/nvidia/deepstream/deepstream-5.0/samples/models/tlt_pretrained_models/peoplenet/resnet34_peoplenet_pruned.etlt
labelfile-path=/opt/nvidia/deepstream/deepstream-5.0/samples/configs/tlt_pretrained_models/labels_peoplenet.txt
# model-engine-file=/opt/nvidia/deepstream/deepstream-5.0/samples/models/tlt_pretrained_models/peoplenet/resnet34_peoplenet_pruned.etlt_b1_gpu0_fp32.engine
input-dims=3;544;960;0
uff-input-blob-name=input_1
batch-size=1
process-mode=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=3
cluster-mode=1
interval=0
gie-unique-id=1
output-blob-names=output_bbox/BiasAdd;output_cov/Sigmoid
[class-attrs-all]
pre-cluster-threshold=0.4
## Set eps=0.7 and minBoxes for cluster-mode=1(DBSCAN)
eps=0.7
minBoxes=1
I got the following error message when I run it.
0:00:11.330941648  6060 0x557d3c97faa0 INFO                 nvinfer gstnvinfer_impl.cpp:311:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:dstensor_pgie_config_peoplenet.txt sucessfully
Running...
** (deepstream-infer-tensor-meta-app:6060): ERROR **: 09:46:48.498: failed to check pgie network info
Trace/breakpoint trap
Please help,
The same config file for pgie (peoplenet TLT model) is working with deepstream test2 sample app.
@vorapolbig
We are looking into this issue and setting up similar environments to reproduce this fault.
I may ask you for extra information if needed later.
Thanks you.
any update on the issue?
