Deepstream fails in Gtk3 window with additional Widgets
• Hardware Platform ( Jetson AGX Orin developer kit)
• DeepStream Version 6.4.0
• JetPack Version (6.0-b52)
• TensorRT Version 8.6.2.3 arm64
• Issue Type( Integration with Gtk3 in C with multi windows)
• How to reproduce the issue ? (Run Deepstream test1 program modified with Gtk3 & builder file)
• Requirement details( I have included minor Gtk3 changes + builder file)
I run deepstream_test1_app.c with Gtk3 modifications. When only a simple video window is included
the video runs and displays without issue, all is perfect. My goal is to have 2 windows the 1st displaying video with buttons (1 button sends control to the 2nd window) and the 2nd window is a maintenance screen. I wish to toggle back & forth between the two windows. This works without issue using a simple autovideosrc and autovideosink in gstreamer - no problems.
When a button widget is added the the 1st window running the deepstream app gives this error:
NvMMLiteOpen : Block : BlockType =261
NvMMLiteBlockCreate : Block : BlockType = 261
Segmentation fault (core dump)
The button (*button1) is added in create_ui function and builder file. Both attached below.
builder file:
<?xml version="1.0" encoding="UTF-8"?>
<!-- Generated with glade 3.38.2 -->
<interface>
  <requires lib="gtk+" version="3.24"/>
  <object class="GtkWindow" id="window1">
    <property name="width-request">1280</property>
    <property name="height-request">720</property>
    <property name="can-focus">False</property>
    <property name="border-width">2</property>
    <property name="title" translatable="yes">DeepStream Gtk+ demo</property>
    <child>
      <object class="GtkFixed" id="fixed1">
        <property name="visible">True</property>
        <child>
          <object class="GtkDrawingArea" id="video_window">
            <property name="width-request">1200</property>
            <property name="height-request">400</property>
            <signal name="realize" handler="on_video_window_realize" swapped="no"/>
          </object>
          <packing>
            <property name="x">1</property>
            <property name="y">44</property>
          </packing>
        </child>
>> This section removed and program works ok <<<
        <child>
          <object class="GtkButton" id="button1">
            <property name="label" translatable="yes">Button</property>
            <property name="width-request">100</property>
            <property name="height-request">40</property>
            <property name="can-focus">True</property>
            <property name="receives-default">True</property>
          </object>
        </child>
      </object>
    </child>
  </object>
</interface>
Code: 96% of this code is the deepstream test 1 code. Hope the volume of this is not over whelming.
// Gtk & Gst
#include <gst/video/videooverlay.h>
#include <gtk/gtk.h>
#include <gdk/gdk.h>
#include <gtk/gtkx.h>
#include <gdk/gdkx.h>
#include <gst/gst.h>
// System
#include <glib.h>
#include <stdio.h>
// Nvidia & Deepstream
#include <cuda_runtime_api.h>
#include "gstnvdsmeta.h"
#include "nvds_yml_parser.h"
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
 * different resolution. The muxer will scale all the input frames to this
 * resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
 * based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 40000
/* Check for parsing error. */
#define RETURN_ON_PARSER_ERROR(parse_expr) \
  if (NVDS_YAML_PARSER_SUCCESS != parse_expr) { \
    g_printerr("Error in parsing configuration file.\n"); \
    return -1; \
// Gtk widgets
GtkWidget *window1, *video_window, *fixed1, *button1;
GtkBuilder *builder;
gint frame_number = 0;
gchar pgie_classes_str[4][32] = { "Vehicle", "TwoWheeler", "Person", "Roadsign"};
/* osd_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
 * and update params for drawing rectangle, object information etc. */
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
    GstBuffer *buf = (GstBuffer *) info->data;
    guint num_rects = 0;
    NvDsObjectMeta *obj_meta = NULL;
    guint vehicle_count = 0;
    guint person_count = 0;
    NvDsMetaList * l_frame = NULL;
    NvDsMetaList * l_obj = NULL;
    NvDsDisplayMeta *display_meta = NULL;
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        int offset = 0;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
                l_obj = l_obj->next) {
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
                vehicle_count++;
                num_rects++;
            if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
                person_count++;
                num_rects++;
        display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
        NvOSD_TextParams *txt_params  = &display_meta->text_params[0];
        display_meta->num_labels = 1;
        txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
        offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
        offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
        /* Now set the offsets where the string should appear */
        txt_params->x_offset = 10;
        txt_params->y_offset = 12;
        /* Font , font-color and font-size */
        txt_params->font_params.font_name = "Serif";
        txt_params->font_params.font_size = 10;
        txt_params->font_params.font_color.red = 1.0;
        txt_params->font_params.font_color.green = 1.0;
        txt_params->font_params.font_color.blue = 1.0;
        txt_params->font_params.font_color.alpha = 1.0;
        /* Text background color */
        txt_params->set_bg_clr = 1;
        txt_params->text_bg_clr.red = 0.0;
        txt_params->text_bg_clr.green = 0.0;
        txt_params->text_bg_clr.blue = 0.0;
        txt_params->text_bg_clr.alpha = 1.0;
        nvds_add_display_meta_to_frame(frame_meta, display_meta);
    g_print ("Frame Number = %d Number of objects = %d "
            "Vehicle Count = %d Person Count = %d\n",
            frame_number, num_rects, vehicle_count, person_count);
    frame_number++;
    return GST_PAD_PROBE_OK;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_ERROR:{
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      if (debug)
        g_printerr ("Error details: %s\n", debug);
      g_free (debug);
      g_error_free (error);
      break;
    default:
      break;
  return TRUE;
static guintptr video_window_handle = 0;
/* This function is called when the main window is closed */
static void window_closed ()
  //stop_cb (NULL, data);
  gtk_window_close(GTK_WINDOW(window1));
  gtk_main_quit ();
static GstBusSyncReply
bus_sync_handler (GstBus * bus, GstMessage * message, gpointer user_data)
 // ignore anything but 'prepare-window-handle' element messages
 if (!gst_is_video_overlay_prepare_window_handle_message (message))
   return GST_BUS_PASS;
 if (video_window_handle != 0) {
   GstVideoOverlay *overlay;
   // GST_MESSAGE_SRC (message) will be the video sink element
   overlay = GST_VIDEO_OVERLAY (GST_MESSAGE_SRC (message));
   gst_video_overlay_set_window_handle (overlay, video_window_handle);
 } else {
   g_warning ("Should have obtained video_window_handle by now!");
 gst_message_unref (message);
 return GST_BUS_DROP;
static void
on_video_window_realize (GtkWidget * video_window, gpointer data)
    gulong xid = GDK_WINDOW_XID (gtk_widget_get_window (video_window));
    video_window_handle = xid;
static void create_ui(gpointer pipeline){
    builder = gtk_builder_new_from_file ("/home/steven/Projects/command-center/build/builder/builder4_8.ui");
    window1 = GTK_WIDGET(gtk_builder_get_object(builder,"window1"));
    g_signal_connect(window1, "destroy", G_CALLBACK(gtk_main_quit), NULL);
    fixed1 = GTK_WIDGET(gtk_builder_get_object(builder,"fixed1"));
    printf("scale factor %d\n", gtk_widget_get_scale_factor (fixed1));
    button1 = GTK_WIDGET(gtk_builder_get_object(builder,"button1"));
    video_window = GTK_WIDGET(gtk_builder_get_object(builder,"video_window"));
    g_signal_connect (video_window, "realize", G_CALLBACK (on_video_window_realize), NULL);
    //gtk_builder_connect_signals(builder, NULL);
    gtk_widget_show_all (window1);
    //gtk_widget_realize (video_window);
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *source = NULL, *h264parser = NULL,
      *decoder = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv = NULL,
      *nvosd = NULL;
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstPad *osd_sink_pad = NULL;
  gboolean yaml_config = FALSE;
  NvDsGieType pgie_type = NVDS_GIE_PLUGIN_INFER;
  int current_device = -1;
  cudaGetDevice(&current_device);
  struct cudaDeviceProp prop;
  cudaGetDeviceProperties(&prop, current_device);
  /* Check input arguments */
  if (argc != 2) {
    g_printerr ("Usage: %s <yml file>\n", argv[0]);
    g_printerr ("OR: %s <H264 filename>\n", argv[0]);
    return -1;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  gtk_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Parse inference plugin type */
  yaml_config = (g_str_has_suffix (argv[1], ".yml") ||
          g_str_has_suffix (argv[1], ".yaml"));
  if (yaml_config) {
    RETURN_ON_PARSER_ERROR(nvds_parse_gie_type(&pgie_type, argv[1],
                "primary-gie"));
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("dstest1-pipeline");
  /* Source element for reading from the file */
  source = gst_element_factory_make ("filesrc", "file-source");
  /* Since the data format in the input file is elementary h264 stream,
   * we need a h264parser */
  h264parser = gst_element_factory_make ("h264parse", "h264-parser");
  /* Use nvdec_h264 for hardware accelerated decode on GPU */
  decoder = gst_element_factory_make ("nvv4l2decoder", "nvv4l2-decoder");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  /* Use nvinfer or nvinferserver to run inferencing on decoder's output,
   * behaviour of inferencing is set through config file */
  if (pgie_type == NVDS_GIE_PLUGIN_INFER_SERVER) {
    pgie = gst_element_factory_make ("nvinferserver", "primary-nvinference-engine");
  } else {
    pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  /* Finally render the osd output */
  if(prop.integrated) {
    sink = gst_element_factory_make("nv3dsink", "nv3d-sink");
  } else {
    sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
  if (!source || !h264parser || !decoder || !pgie
      || !nvvidconv || !nvosd || !sink) {
    return -1;
  /* we set the input filename to the source element */
  g_object_set (G_OBJECT (source), "location", argv[1], NULL);
  if (g_str_has_suffix (argv[1], ".h264")) {
    g_object_set (G_OBJECT (streammux), "batch-size", 1, NULL);
    g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
        MUXER_OUTPUT_HEIGHT,
        "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
    /* Set all the necessary properties of the nvinfer element,
     * the necessary ones are : */
    g_object_set (G_OBJECT (pgie),
        "config-file-path", "dstest1_pgie_config.txt", NULL);
  if (yaml_config) {
    RETURN_ON_PARSER_ERROR(nvds_parse_file_source(source, argv[1],"source"));
    RETURN_ON_PARSER_ERROR(nvds_parse_streammux(streammux, argv[1],"streammux"));
    /* Set all the necessary properties of the inference element */
    RETURN_ON_PARSER_ERROR(nvds_parse_gie(pgie, argv[1], "primary-gie"));
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_bus_set_sync_handler (bus, (GstBusSyncHandler) bus_sync_handler, NULL,
      NULL);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
  gst_bin_add_many (GST_BIN (pipeline),
      source, h264parser, decoder, streammux, pgie,
      nvvidconv, nvosd, sink, NULL);
  g_print ("Added elements to bin\n");
  GstPad *sinkpad, *srcpad;
  gchar pad_name_sink[16] = "sink_0";
  gchar pad_name_src[16] = "src";
  //sinkpad = gst_element_get_request_pad (streammux, pad_name_sink); Deprecated
  sinkpad = gst_element_request_pad_simple (streammux, pad_name_sink);
  if (!sinkpad) {
    g_printerr ("Streammux request sink pad failed. Exiting.\n");
    return -1;
  srcpad = gst_element_get_static_pad (decoder, pad_name_src);
  if (!srcpad) {
    g_printerr ("Decoder request src pad failed. Exiting.\n");
    return -1;
  if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
      g_printerr ("Failed to link decoder to stream muxer. Exiting.\n");
      return -1;
  gst_object_unref (sinkpad);
  gst_object_unref (srcpad);
  /* we link the elements together */
  /* file-source -> h264-parser -> nvh264-decoder ->
   * pgie -> nvvidconv -> nvosd -> video-renderer */
  if (!gst_element_link_many (source, h264parser, decoder, NULL)) {
    g_printerr ("Elements could not be linked: 1. Exiting.\n");
    return -1;
  if (!gst_element_link_many (streammux, pgie,
        nvvidconv, nvosd, sink, NULL)) {
      g_printerr ("Elements could not be linked: 2. Exiting.\n");
      return -1;
  /* prepare the ui */
  create_ui(pipeline);
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  osd_sink_pad = gst_element_get_static_pad (nvosd, "sink");
  if (!osd_sink_pad)
    g_print ("Unable to get sink pad\n");
  else
    gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
        osd_sink_pad_buffer_probe, NULL, NULL);
  gst_object_unref (osd_sink_pad);
  /* Set the pipeline to "playing" state */
  g_print ("Using file: %s\n", argv[1]);
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_print ("Running...\n");
  //g_main_loop_run (loop);
  // Gtk3 execute loop
  gtk_main ();
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
This seems to be a GTK problem, I don’t know much about it.
Please try the solution below, I think it is caused by nv3dsink being incompatible with GTK.
You can try to go to the GTK community to discuss the problem.
 * SPDX-FileCopyrightText: Copyright (c) 2018-2024 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
 * SPDX-License-Identifier: LicenseRef-NvidiaProprietary
 * NVIDIA CORPORATION, its affiliates and licensors retain all intellectual
 * property and proprietary rights in and to this material, related
 * documentation and any modifications thereto. Any use, reproduction,
 * disclosure or distribution of this material and related documentation
 * without an express license agreement from NVIDIA CORPORATION or
 * its affiliates is strictly prohibited.
#include <glib.h>
#include <stdio.h>
 * resolution. */
    return -1; \
  "Roadsign"
    gpointer u_data)
        int offset = 0;
                vehicle_count++;
                num_rects++;
                person_count++;
                num_rects++;
    frame_number++;
static gboolean
      break;
      gchar *debug;
      GError *error;
      if (debug)
      g_free (debug);
      break;
    default:
      break;
  return TRUE;
static void window_closed (GtkWidget *widget, GdkEvent *event, void *data) {
  gtk_main_quit ();
   GstVideoOverlay *overlay = GST_VIDEO_OVERLAY (GST_MESSAGE_SRC (message));
 } else {
static void
video_widget_realize_cb (GtkWidget * video_window, gpointer data)
#if GTK_CHECK_VERSION(2,18,0)
  // Tell Gtk+/Gdk to create a native window for this widget instead of
  // drawing onto the parent widget.
  // This is here just for pedagogical purposes, GDK_WINDOW_XID will call
  // it as well in newer Gtk versions
  if (!gdk_window_ensure_native (gtk_widget_get_window (video_window)))
    g_error ("Couldn't create native window needed for GstVideoOverlay!");
#endif
#ifdef GDK_WINDOWING_X11
#endif
#ifdef GDK_WINDOWING_WIN32
    HWND wnd = GDK_WINDOW_HWND (gtk_widget_get_window (video_window));
    video_window_handle = (guintptr) wnd;
#endif
int
      *nvosd = NULL;
  GstBus *bus = NULL;
  guint bus_watch_id;
  GtkWidget *window, *video_window;
  GstStateChangeReturn sret;
  if (argc != 2) {
    return -1;
  if (yaml_config) {
                "primary-gie"));
    return -1;
  } else {
  GstElement *nvvidconv2 = gst_element_factory_make ("nvvideoconvert", "nvvideo-convert2");
    //sink = gst_element_factory_make("nv3dsink", "nv3d-sink");
    sink = gst_element_factory_make("autovideosink", "nv3d-sink");
  } else {
#ifdef __aarch64__
    sink = gst_element_factory_make ("nv3dsink", "nvvideo-renderer");
#else
#endif
      || !nvvidconv || !nvosd || !nvvidconv2 || !sink) {
    return -1;
  if (yaml_config) {
      NULL);
      nvvidconv, nvosd, nvvidconv2, sink, NULL);
  if (!sinkpad) {
    return -1;
  if (!srcpad) {
    return -1;
      return -1;
    return -1;
        nvvidconv, nvosd, nvvidconv2, sink, NULL)) {
      return -1;
  window = gtk_window_new (GTK_WINDOW_TOPLEVEL);
  g_signal_connect (G_OBJECT (window), "delete-event", G_CALLBACK (window_closed), (gpointer) pipeline);
  gtk_window_set_default_size (GTK_WINDOW (window), 1280, 960);
  gtk_window_set_title (GTK_WINDOW (window), "DeepStream Gtk+ demo");
  gtk_container_set_border_width (GTK_CONTAINER (window), 2);
  GtkWidget *vbox = gtk_box_new (GTK_ORIENTATION_VERTICAL, 0);
  // add vbox to window
  gtk_container_add (GTK_CONTAINER (window), vbox);
  // printf("scale factor %d\n", gtk_widget_get_scale_factor (box));
  video_window = gtk_drawing_area_new ();
  g_signal_connect (video_window, "realize", G_CALLBACK (video_widget_realize_cb), NULL);
  gtk_widget_set_double_buffered (video_window, FALSE);
  // add video window to vbox
  gtk_box_pack_start (GTK_BOX (vbox), video_window, TRUE, TRUE, 0);
  GtkWidget *hbox = gtk_box_new (GTK_ORIENTATION_HORIZONTAL, 0);
  GtkWidget *hello_button = gtk_button_new_with_label("Hello World");
  GtkWidget *quit_button = gtk_button_new_with_label("Quit");
  gtk_box_pack_start (GTK_BOX (hbox), hello_button, FALSE, FALSE, 0);
  gtk_box_pack_start (GTK_BOX (hbox), quit_button, FALSE, FALSE, 0);
  // add hbox to vbox
  gtk_box_pack_start(GTK_BOX(vbox), hbox, FALSE, TRUE, 0);
  gtk_widget_show_all (window);
  if (!osd_sink_pad)
  else
  gtk_main ();
  return 0;
I get the same error, earlier, the video doesn’t display, however the code that tracks vehicle counts displays
in terminal. I think deepstream gstreamer elements don’t play well in the Gtk sandbox. That’s a shame. how does one create UI windows to present and manipulate actions/events?
I can only assume other nvidia elements in the deepstream tool kit will have similar issues. I’ll play with this a little longer and see if I can write interfaces to CUDA & Tensor myself. I had high hopes for deepstream.
You can refer to my example above and use autovideosink as workaround. This element can work normally with the GUI.
I replaced:
sink = gst_element_factory_make(“nv3dsink”, “nv3d-sink”);
} else {
sink = gst_element_factory_make (“nveglglessink”, “nvvideo-renderer”);
with:
sink = gst_element_factory_make(“autovideosink”, “sink”);
OR
sink = gst_element_factory_make(“autovideosink”, “nv3d-sink”);
I get same errors and a black screen. This must require more modifications & I’m making it too simple.
I think it best I go have a look at Dustin Franklin’s code he created for inference and see if I can
use his backend on my Gtk ui’s. I have many projects needing this to work and I can’t spend more time pulling deepstream apart. If there is another way to get a better & faster path to understand deepstream I’m all ears, otherwise back to Dusty I go…
Have you tried my code above? I also use AGX orin. I have tested it and it is good.
I think your problem may be caused by using .xml to generate GUI.
In addition, I think the control is placed on the top of the overlay, which requires more skills.
I run your exact program. I noticed this line of code was deprecated so I commented it out:
// gtk_widget_set_double_buffer (video_window, FALSE);
Hmmm. You had this in your code so maybe you are using a different version of Gtk3 than I?
I ran your exact code in my environment. See Versions below.
As you suggested I made change:
sink = gst_element_factory_make(“autovidiosink”, “nv3d-sink”);
in place of “nv3dsink”
The screen appears with the video window be all green.
In the Terminal window I get then standard data and then “Running…” displays.
Then
NvMMLiteOpen : Block : BlockType = 261
Then
Frame number = 0 Number of objects = 17 Vehicle Count =11 person Count = 6
Versions:
Host name             DEVELOPMENT-ORIN
Operating System      Ubuntu 22.04.4 LTS
Architecture          arm64
Model                 NVIDIA Jetson AGX Orin Developer Kit
Memory                Maximum Capacity: 64 GB
Kernel                Linux 5.15.122-tegra
Development Tools                             Version               Architecture
Docker                                        26.1.1
Python3                                       3.10.12
TensorRT                                      8.6.2.3               arm64
gtk+3.0                                       3.24.33-1ubuntu2      arm64
Nvidia Applications                           Version               Architecture
Jetpack                                       6.0-b52               arm64
deepstream-app                                6.4.0
DeepStreamSDK                                 6.4.0
Tegra Release L4T                             R36.2.0               aarch64
CUDA CCCL                                     12.2.140              arm64
NVIDIA CUDA Package                           36.2.0                arm64
NVIDIA CUDA Debugger Support Package          12.2-33282765.0       arm64
Gstreamer                                     Version               Architecture
GStreamer plugin for GTK+3                    1.20.3                arm64
Tools for use with GStreamer                  1.20.3                arm64
GStreamer plugins for X11 and Pango           1.20.1                arm64
NVIDIA GST Application files                  36.2.0-20231218214829 arm64
GTK-3 Applications                            Version               Architecture
NVIDIA GST Application files GTK graphical... 3.24.33               arm64
I use the same GTK version, the only difference is that I upgraded DS-7.0, you can try that version
