No i haven’t disabled the source in my config file, here is another output using the config below(CSI as source and RTSP sink)
sudo ./deepstream-test5-app -c configs/custom.txt
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:239>: Pipeline ready
** INFO: <bus_callback:225>: Pipeline running
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3280 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3280 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 4
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 59.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
Active sources : 1
**PERF: FPS 0 (Avg)
Wed Oct 4 12:18:47 2023
**PERF: 30.14 (3.22)
Active sources : 0
Wed Oct 4 12:18:52 2023
**PERF: 0.00 (1.55)
Active sources : 0
Wed Oct 4 12:18:57 2023
**PERF: 0.00 (1.02)
(deepstream-test5-app:79327): GLib-GObject-WARNING **: 12:24:45.283: value "TRUE" of type 'gboolean' is invalid or out of range for property 'sync' of type 'gboolean'
(deepstream-test5-app:79327): GLib-GObject-WARNING **: 12:24:45.283: value "TRUE" of type 'gboolean' is invalid or out of range for property 'qos' of type 'gboolean'
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
Camera index = 0
Camera mode = 4
seconds to Run = 0
Active sources : 1
**PERF: FPS 0 (Avg)
Wed Oct 4 12:24:50 2023
**PERF: 30.02 (29.97)
Active sources : 1
Wed Oct 4 12:24:55 2023
**PERF: 30.00 (29.98)
Active sources : 1
Wed Oct 4 12:25:00 2023
**PERF: 30.01 (29.99)
Active sources : 1
Wed Oct 4 12:25:05 2023
Active sources : 1
Wed Oct 4 12:25:10 2023
^C** ERROR: <_intr_handler:712>: User Interrupted..
Quitting
nvstreammux: Successfully handled EOS for source_id=0
