DeepStream frame data garbage collection causing silent halt in multi-process pipeline
I’m running DeepStream in a separate process from my main logic loop. The DeepStream process puts detections in a shared queue, while my processor reads from this queue and handles core logic.
My DeepStream pipeline: streammux -> nvvidconv -> filter -> pgie
I added nvvidconv + filter to capture frame images, but initially only passed frame_meta.batch_id and hash(gst_buffer) to the shared queue, planning to retrieve frames as needed in my processor.
This worked when my processor pipeline was simple, but now there’s slight latency between detection (DeepStream) and core logic (processor). When I run:
pyds.get_nvds_buf_surface(gst_buffer_hash, frame_batch_id)
My core logic process halts silently.
I suspect DeepStream’s garbage collector removes frame data before my processor can retrieve it.
I fixed this by passing the result of the above code directly to the shared queue in the DeepStream process, but what’s the performance impact of this solution?
Note that I still need to run this code to get the actual image matrix:
frame_data = np.array(frame, copy=True, order="C")
frame_data = cv2.cvtColor(frame_data, cv2.COLOR_RGBA2BGRA)
• DeepStream Version
• TensorRT Version
@fanzh Thanks for your reply.
  • Hardware Platform: GPU
  • DeepStream Version: 6.2
  • TensorRT Version: 10.3.0.26
  • NVIDIA GPU Driver Version: 535.230.02
  • Issue Type: Question
I’ve used the deepstream_test_3.py as the base pipeline for loading multiple sources, and added nvvidconv, caps, and filter configs from deepstream_imagedata-multistream.py to the start of the pipeline to be able to extract image matrix data to numpy array.
    # Add nvvidconv1 and filter1 to convert the frames to RGBA
    # which is easier to work with in Python.
    print("Creating nvvidconv1 \n ")
    nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
    if not nvvidconv1:
        sys.stderr.write(" Unable to create nvvidconv1 \n")
    print("Creating filter1 \n ")
    caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
    filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
    if not filter1:
        sys.stderr.write(" Unable to get the caps filter1 \n")
    filter1.set_property("caps", caps1)
    print("Creating tiler \n ")
    if not platform_info.is_integrated_gpu():
        # Use CUDA unified memory in the pipeline so frames
        # can be easily accessed on CPU in Python.
        mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
        streammux.set_property("nvbuf-memory-type", mem_type)
        nvvidconv.set_property("nvbuf-memory-type", mem_type)
        if platform_info.is_wsl():
            #opencv functions like cv2.line and cv2.putText is not able to access NVBUF_MEM_CUDA_UNIFIED memory
            #in WSL systems due to some reason and gives SEGFAULT. Use NVBUF_MEM_CUDA_PINNED memory for such
            #usecases in WSL. Here, nvvidconv1's buffer is used in tiler sink pad probe and cv2 operations are
            #done on that.
            print("using nvbuf_mem_cuda_pinned memory for nvvidconv1\n")
            vc_mem_type = int(pyds.NVBUF_MEM_CUDA_PINNED)
            nvvidconv1.set_property("nvbuf-memory-type", vc_mem_type)
        else:
            nvvidconv1.set_property("nvbuf-memory-type", mem_type)
        tiler.set_property("nvbuf-memory-type", mem_type)
And here’s my pipeline:
   streammux.link(nvvidconv1)
   nvvidconv1.link(filter1)
   filter1.link(pgie)
And I added a buffer pad probe to my pgie to get the final detections and send them to a shared process queue:
    pgie_src_pad = pgie.get_static_pad("src")
    if pgie_src_pad:
        pgie_src_pad.add_probe(
            Gst.PadProbeType.BUFFER,
            pgie_src_pad_buffer_probe,
            frame_data_queue,
And in the probe function I have:
    def pgie_src_pad_buffer_probe(pad, info, frame_data_queue: multiprocessing.Queue):
        gst_buffer = info.get_buffer()
        if not gst_buffer:
            return Gst.PadProbeReturn.OK
        gst_buffer_hash = hash(gst_buffer)
        batch_meta = pyds.gst_buffer_get_nvds_batch_meta(gst_buffer_hash)
        if not batch_meta:
        l_frame = batch_meta.frame_meta_list
        while l_frame is not None:
            try:
            except StopIteration:
                break
            detections = build_dict_from_ds_detections(frame_meta)
            detections['gst_buffer_hash'] = gst_buffer_hash
            detections['batch_id'] = frame_meta.batch_id
            frame_data_queue.put(detections)
            try:
                l_frame = l_frame.next
                break
And in my main logic process, I read the frame_data_queue and extract frame image matrix when needed like this:
frame_data = frame_data_queue.get(timeout=1)
frame = pyds.get_nvds_buf_surface(frame_data["gst_buffer_hash"], frame_data["batch_id"])
But this results in my main logic process to halt silently. Instead when inside of the pgie_src_pad_buffer_probe probe function I store the result of get_nvds_buf_surface() function to the frame_data_queue it decreases the performance of the DeepStream on 20 streams from 30 to 6 FPS!
What I’m essentially going to do with the retrieved frame image is sending it to kafka or saving it locally without any changes.
  1. About the halt issue, please make sure all ‘gst_buffer’ will be freed when there are not used , you can print the reference count of gst_buffer to check.
  2. About the “low fps” issue, what is the source type(local file or rtsp)? what is fps? please measure the time consumption in probe function. Please check if any functions are taking too much time.
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks! do you need to retrieve every frame? if so, you can use nvds_obj_enc_process and nvds_obj_enc_finish which have GPU acceleration, to save frames. Here is the sample code. if not, you can use this sample code.
Sorry for the late response.
I’m was using videos as source.
I noticed the low FPS was because of the queue lock, but still passing the raw frame data was inefficient so I tried using nvjpegenc with tee to extract the encoded binary images.
