DeepStream gets stuck with RTSP stream
Jetson AGX Xavier
• DeepStream Version
Deepstream 6.0.1
Jetpack 4.6
• TensorRT Version
Tensor 8
Question
deepstream-nvdsanalytics
• Issue
I’m working on a system that uses Deepstream with NVDSAnalytics. The system uses two RTSP streams as inputs and line-crossing-stream to identify when an object enters a region of interest. Currently, I’m using the bus_call function to identify and correct errors in the system, for example, when a camera disconnects, it detects and reconnects it. The system works well; however, after weeks of normal operation, Deepstream stops working, and bus_call doesn’t provide any error message, so the system can’t identify the problem and freezes. What tools can I use to determine the error and correct it?
I’ve noticed that this is a recurring error in this version of Deepstream 6. Unfortunately, I cannot update Deepstream or the hardware since I have to provide support to several clients who have purchased my system.
what is the complete media pipeline? could you share the running log? wondering if there are some abnormal printings? could you simplify the pipeline to check which plugin cause the hang issue?
