**• Hardware Platform (Jetson / GPU) GPU • DeepStream Version 5.01 • JetPack Version (valid for Jetson only) • TensorRT Version 7.2 • NVIDIA GPU Driver Version (valid for GPU only) 450.80.02 • Issue Type( questions, new requirements, bugs) bugs • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
hi, my deepstream app sometime hangs, here is some bt of gdb:
1 what is your GPU product model?
2 are you using deepstream-app to test? what is your start command?
3 did you do some code modification? please upload your diff.
I use a Tesla P4 GPU product, and write my own pipeline, it is just a simple IVA pipeline, but i have so many short mp4 file to process, so every time i create a new pipeline, and process a mp4 file. after this file is processed done, i destory this pipeline, and create another pipeline to process another mp4 file.
don’t recommend to always recreate pipeline, here are some solutions:
1 you can input many files at once, please refer to /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-app
@user130795 Back to your hang issue,
1 please upgrade to deepstream6.0.1 because we have fixed some bugs, and check if there is still that hang issue. here is the link:Quickstart Guide — DeepStream 6.1.1 Release documentation
2 please provide your code, we will reproduce this hang issue by your code.
