deepstream How to operate read usb camera, c++ code, not config file way.THNAKS
You can build a pipleline with source as v4l2src based on existing samples deepstream_testN (similar as example here : Accelerated GStreamer — Jetson Linux Developer Guide documentation (nvidia.com))
//one stream can work,two streams error::::source1 no link(-1)
#include <gst/gst.h>
#define MUXER_BATCH_TIMEOUT_USEC 400000
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
GMainLoop *loop = (GMainLoop *) data;
switch (GST_MESSAGE_TYPE (msg)) {
case GST_MESSAGE_EOS:
g_print (“End of stream\n”);
g_main_loop_quit (loop);
break;
case GST_MESSAGE_ERROR:{
gchar *debug;
GError *error;
gst_message_parse_error (msg, &error, &debug);
g_printerr (“ERROR from element %s: %s\n”,
GST_OBJECT_NAME (msg->src), error->message);
if (debug)
g_printerr (“Error details: %s\n”, debug);
g_free (debug);
g_error_free (error);
break;
default:
break;
return TRUE;
int main(int argc, char *argv)
guint bus_watch_id;
GMainLoop *loop = NULL;
GstElement *bin, *pipeline, *source, *convert1,*filter1,*convert2,*filter2,*convert3, *muxsink,*infer,*tiler,*transform,*sink,*source1,*filter_1, *filter_2, *convert_1,*source_fake,
*sink_fake ,*queue1;
GstBus *bus;
GstCaps *caps1,*caps2,*caps_1,*caps_2;
GstStateChangeReturn ret;
gst_init(&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
pipeline = gst_pipeline_new(“wtf-pipeline”);
source = gst_element_factory_make(“v4l2src”, “source”);
filter1 = gst_element_factory_make(“capsfilter”, “filter”);
filter2 = gst_element_factory_make(“capsfilter”, “filter2”);
convert1 = gst_element_factory_make(“nvvidconv”, “convert”);
convert3 = gst_element_factory_make(“nvvideoconvert”, “convert3”);
muxsink = gst_element_factory_make(“nvstreammux”, “muxsink”);
transform = gst_element_factory_make(“nvegltransform”, “transform”);
sink = gst_element_factory_make(“nveglglessink”, “sink”);
tiler = gst_element_factory_make (“nvmultistreamtiler”, “nvtiler”);
//gst_bin_add (GST_BIN (pipeline), bin);
source1 = gst_element_factory_make(“v4l2src”, “source1”);
filter_1 = gst_element_factory_make(“capsfilter”, “filter-1”);
filter_2 = gst_element_factory_make(“capsfilter”, “filter-2”);
convert_1 = gst_element_factory_make(“nvvidconv”, “convert-1”);
queue1 = gst_element_factory_make (“queue”, “queue1”);
gst_bin_add (GST_BIN (pipeline), source1);
gst_bin_add (GST_BIN (pipeline), filter_1);
gst_bin_add (GST_BIN (pipeline), filter_2);
gst_bin_add (GST_BIN (pipeline), convert_1);
gst_bin_add (GST_BIN (pipeline), tiler);
if (!pipeline || !source
|| !filter1 || !filter2 || !convert1||!convert3||!muxsink ||!transform||!sink||!tiler
g_printerr (“One element could not be created. Exiting.\n”);
return -1;
gst_bin_add_many(GST_BIN(pipeline), source,filter1,convert1,filter2, muxsink,queue1,convert3,transform,sink, NULL);
if (!gst_element_link_many(source,filter1,convert1,filter2,NULL))
g_printerr (“Elements could not be linked: 1. Exiting.\n”);
return -1;
if (!gst_element_link_many(source1,filter_1,convert_1,filter_2,NULL))
g_printerr (“Elements could not be linked: 2. Exiting.\n”);
return -1;
caps1 = gst_caps_new_simple(“video/x-raw”,
“width”, G_TYPE_INT, 1920,
“height”, G_TYPE_INT, 1080,
“framerate”, GST_TYPE_FRACTION, 30,
1, NULL);
caps2 = gst_caps_new_simple(“video/x-raw(memory:NVMM)”,
“format”,G_TYPE_STRING,“(string)NV12”,
“width”, G_TYPE_INT, 960,
“height”, G_TYPE_INT, 540,
1, NULL);
caps_1 = gst_caps_new_simple(“video/x-raw”,
1, NULL);
caps_2 = gst_caps_new_simple(“video/x-raw(memory:NVMM)”,
1, NULL);
g_object_set(G_OBJECT(source), “device”,“/dev/video0”, NULL);
g_object_set(G_OBJECT(source1), “device”,“/dev/video2”, NULL);
g_object_set(G_OBJECT(filter1), “caps”, caps1, NULL);
g_object_set(G_OBJECT(filter2), “caps”, caps2, NULL);
g_object_set(G_OBJECT(filter_1), “caps”, caps_1, NULL);
g_object_set(G_OBJECT(filter_2), “caps”, caps_2, NULL);
g_object_set(G_OBJECT(muxsink),“width”,960,“height”,540, “batch-size”, 4, “live-source”, 1, “batched-push-timeout”, MUXER_BATCH_TIMEOUT_USEC, NULL);
g_object_set (G_OBJECT (tiler), “rows”, 2, “columns”, 2,
“width”, 1920, “height”,1080, NULL);
GstPad *source_pad = gst_element_get_static_pad(filter2, “src”);
guint i=0;
gchar pad_name[16]= {};
g_snprintf(pad_name, 15, “sink_%u”,i);
GstPad *sink_pad = gst_element_get_request_pad(muxsink,pad_name);
gst_pad_link(source_pad, sink_pad);
GstPad *source_pad_1 = gst_element_get_static_pad(filter_2, “src”);
guint k=1;
gchar pad_name_1[16]= {};
g_snprintf(pad_name_1, 15, “sink_%u”,k);
GstPad *sink_pad_1 = gst_element_get_request_pad(muxsink,pad_name_1);
gst_pad_link(source_pad_1, source_pad_1);
gst_element_link_many(muxsink,queue1,tiler,convert3,transform,sink,NULL);
gst_element_set_state(pipeline, GST_STATE_PLAYING);
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
g_main_loop_run (loop);
gst_element_set_state (pipeline, GST_STATE_NULL);
gst_object_unref (pipeline);
return 0;
If you want to use multiple sources, we suggest you use the uri_decode_bin
. You can refer to the source code: deepstream_test3_app.c
