DeepStream: How to save decoded frame in .jpg format (or OpenCV Mat) in decoder(decPerf) pipeline
Dear DeepStream community,
I would like to access the decoded frame. Following is my query
  1. After decoding is done, I want the frame to be copied to OpenCV Mat and perform further analysis on Mat data
Can anyone please help me how to achieve this?
Thanks,
Siddartha
Please remember to apply a color space conversion before translating image into cv::Mat.
Flow: Decode ▶ Color Converter ▶ OpenCV
After conversion, data is located at vpInputTensors[0]->getConstCpuData().
Then, you can create cvMat from the data pointer:
const float *data = reinterpret_cast<const float*>(vpInputTensors[0]->getConstCpuData());
cv::Mat mat(height, width, 16, data);
Thank you for the reply.
I have tried the following:
Have added the custom module where after addColorSpaceConvertorTask to BGR_PLANAR type, I create Mat object in execute() API. But what I get is the corrupted frame when I save.
Below is the snippet:
IDeviceWorker *pDeviceWorker = createDeviceWorker(g_nChannels, g_devID_infer);
pDeviceWorker->addDecodeTask(cudaVideoCodec_H264);
IModule *pConvertor = pDeviceWorker->addColorSpaceConvertorTask(BGR_PLANAR);
PRE_MODULE_LIST module1;
module1.push_back(std::make_pair(pConvertor, 0));
OpencvModule *opencv = new OpencvModule(module1, …);
assert(nullptr != opencv);
pDeviceWorker->addCustomerTask(opencv);
void OpencvModule::execute(const ModuleContext& context, const std::vector<IStreamTensor *>& vpInputTensors, const std::vector<IStreamTensor *>& vpOutputTensors)
assert(1 == vpInputTensors.size());
cout<<vpInputTensors[0]->getTensorType()<<endl;   //  0
cout<<vpInputTensors[0]->getMemoryType()<<endl;   //  0
cout<<vpInputTensors[0]->getElemSize()<<endl;     //  4
cout<<shape_0[0]<<endl; // 1
cout<<shape_0[1]<<endl; // 3
cout<<shape_0[2]<<endl; // 720
cout<<shape_0[3]<<endl; // 1280
const float *pCov = reinterpret_cast<const float*>(vpInputTensors[0]->getConstCpuData());
cv::Mat image(shape_0[2], shape_0[3], 16, &pCov);
cv::imwrite("img1.jpg",image);
Can you please help me to get the correct image.
Please find attached output image
Can anyone help me to resolve the above issue?
Thanks,
Siddartha
You may also need a data format converter.
addColorSpaceConvertor: image format is CHW.
Ex. b1, b2, …, g1, g2, …, r1, r2, …
OpenCV: image format is HWC.
Ex. b1, g1, r1, b2, g2, r2, …
Is decPerf available in deepstream sdk for jetson Xavier?
I am not able to locate source code in samples or source folders.
Sorry for the late.
The module changes location. You can enable the perf with the configure like this:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
The source code is located at ${deepstream_sdk_on_jetson}/sources/apps/apps-common/src/deepstream_perf.c.
