I am struggling around to figure out how to run the deepstream-image-meta-test app.
I am working with Jetson TX2 and DS 5.0
I tried to run it with below command
"ubuntu@dhcp-10-24-142-103:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-image-meta-test$ ./deepstream-image-meta-test …/…/…/…/samples/streams/sample_720p.mp4
Facing this error → ERROR from element uri-decode-bin: Invalid URI “…/…/…/…/samples/streams/sample_720p.mp4”.
I could run the app but it is failing with a segmentation fault at
nvds_obj_enc_finish(ctx) in the pgie_src_pad_buffer_probe() of the deepstream_image_meta_test.c file
HI,
Did you make some changes? Is that possible to share for recreating your issue? or you could get the back trace after issue happened and paste here.
I haven’t done any change.
Can you help me with steps to generate the core dump for the backtrace.
Editing the Makefile to add the -g option and running the binary is not generating the core dump.
P.S - I have set the ulimit -c to unlimited. I have installed the gdb with apt-get tool.
Hope this link helps, Hunting the core | FromDual.
or you could rm ~/.cache/gstreamer-1.0/ -rf and run the sample again, if issue still there, you could get the log by
GST_DEBUG=:level app > logname 2>&1
