Deepstream line crossing extended=0 error
Hi Team,
am trying to use deepstream line crossing for person entry and exit and i read
when i set extended=0
Boolean parameter to check crossings only on the configured line or for the extended line covering the video frame.
I set extended=0 but i see when person crossing next to configured line, entry got added how to fix this
thank you
• DeepStream Version
• TensorRT Version
can you provide the information above? could you provide the test video and configuration file? I will use deepstream-nvdsanalytics-test to reproduce this issue. Thanks!
