I am trying to run NVIDIA sample License Plate Recognition app deepstream_lpr_app for U.S. license plates on NVIDIA Xavier NX 8GB with JetPack 5.1.1, DeepStream 6.2 and TensorRT 8.5.2 and get the following errors:
- ERROR: [TRT]: 3: Cannot find binding of given name: output_bbox/BiasAdd
- ERROR: [TRT]: 3: Cannot find binding of given name: output_cov/Sigmoid
- ERROR: [TRT]: 3: [builder.cpp::~Builder::307] Error Code 3: API Usage Error (Parameter check failed at: optimizer/api/builder.cpp::~Builder::307, condition: mObjectCounter.use_count() == 1. Destroying a builder object before destroying objects it created leads to undefined behavior.)
Please find the full output below:
artem@ubuntu:~/Projects/deepstream_lpr_app/deepstream-lpr-app$ ./deepstream-lpr-app 1 3 0 infer /home/artem/Downloads/us_cars.mp4 output.264
use_nvinfer_server:0, use_triton_grpc:0
Request sink_0 pad from streammux
Warning: 'input-dims' parameter has been deprecated. Use 'infer-dims' instead.
Now playing: 1
Using winsys: x11
Opening in BLOCKING MODE
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:06.803720845 3613 0xaaaab87f3f60 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary-infer-engine2> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 3]: deserialized trt engine from :/home/artem/Projects/deepstream_lpr_app/models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine
INFO: [FullDims Engine Info]: layers num: 3
0 INPUT kFLOAT image_input 3x48x96 min: 1x3x48x96 opt: 16x3x48x96 Max: 16x3x48x96
1 OUTPUT kINT32 tf_op_layer_ArgMax 24 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT tf_op_layer_Max 24 min: 0 opt: 0 Max: 0
0:00:06.891514941 3613 0xaaaab87f3f60 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary-infer-engine2> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1876> [UID = 3]: Could not find output layer 'output_bbox/BiasAdd' in engine
0:00:06.891637150 3613 0xaaaab87f3f60 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary-infer-engine2> NvDsInferContext[UID 3]: Warning from NvDsInferContextImpl::checkBackendParams() <nvdsinfer_context_impl.cpp:1876> [UID = 3]: Could not find output layer 'output_cov/Sigmoid' in engine
0:00:06.891709854 3613 0xaaaab87f3f60 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary-infer-engine2> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 3]: Use deserialized engine model: /home/artem/Projects/deepstream_lpr_app/models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine
0:00:06.932521622 3613 0xaaaab87f3f60 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary-infer-engine2> [UID 3]: Load new model:lpr_config_sgie_us.txt sucessfully
WARNING: Deserialize engine failed because file path: /home/artem/Projects/deepstream_lpr_app/deepstream-lpr-app/../models/tao_pretrained_models/yolov4-tiny/yolov4_tiny_usa_deployable.etlt_b16_gpu0_int8.engine open error
0:00:08.054387150 3613 0xaaaab87f3f60 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary-infer-engine1> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 2]: deserialize engine from file :/home/artem/Projects/deepstream_lpr_app/deepstream-lpr-app/../models/tao_pretrained_models/yolov4-tiny/yolov4_tiny_usa_deployable.etlt_b16_gpu0_int8.engine failed
0:00:08.146291313 3613 0xaaaab87f3f60 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary-infer-engine1> NvDsInferContext[UID 2]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 2]: deserialize backend context from engine from file :/home/artem/Projects/deepstream_lpr_app/deepstream-lpr-app/../models/tao_pretrained_models/yolov4-tiny/yolov4_tiny_usa_deployable.etlt_b16_gpu0_int8.engine failed, try rebuild
0:00:08.146413266 3613 0xaaaab87f3f60 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary-infer-engine1> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 2]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:375: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: onnx2trt_utils.cpp:403: One or more weights outside the range of INT32 was clamped
WARNING: [TRT]: builtin_op_importers.cpp:5243: Attribute caffeSemantics not found in plugin node! Ensure that the plugin creator has a default value defined or the engine may fail to build.
WARNING: [TRT]: DLA requests all profiles have same min, max, and opt value. All dla layers are falling back to GPU
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 125) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 207) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 208) [Shuffle]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 210) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 217) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 218) [Shuffle]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 224) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 225) [Shuffle]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 289) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 290) [Shuffle]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 293) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 294) [Shuffle]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 298) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 299) [Shuffle]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 555) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 556) [Shuffle]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 559) [Constant]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor (Unnamed Layer* 560) [Shuffle]_output, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
WARNING: [TRT]: Missing scale and zero-point for tensor BatchedNMS, expect fall back to non-int8 implementation for any layer consuming or producing given tensor
