Deepstream-lpr-python-version
• GeForce GTX 1660 Ti Mobile
• DeepStream 6.1
• Ubuntu 20.04
• TensorRT 8.2.5.1
• GStreamer 1.16.2
• NVIDIA driver 510.47.03
• CUDA 11.6 Update 1
I want to start deepstream-lpr-python-version (GitHub - preronamajumder/deepstream-lpr-python-version: Python version for NVIDIA Deepstream's LPR. https://developer.nvidia.com/blog/creating-a-real-time-license-plate-detection-and-recognition-app/) project. But for start it I need to generate .engine file. There is no version tlt-converter for CUDA 11.6 and TensorRT 8.2.5.1 (may be i did’nt find it).
How I can generate engine file?
tao-converter is available in NGC. TAO Converter | NVIDIA NGC
For DS 6.1 dGPU, you need to download v3.21.11_trt8.0_x86 version
I have this error after starting converter
I tried to use v3.22.05_trt8.2_x86 version and got this error:
Please double check your command line. And make sure the .etlt file is available.
It’s available, but lavels file is empty. I downloaded it by download_us.sh
Please share the full command line and log again. Not use screenshot, please.
When I use v3.22.05_trt8.2_x86 version:
codeinside@CI-1442:~/deepstream_lpr_app$ sudo sh ./tao-converter -k nvidia_tlt -p image_input,1x3x48x96,4x3x48x96,16x3x48x96            models/LP/LPR/us_lprnet_baseline18_deployable.etlt -t fp16 -e models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine
./tao-converter: 7: Syntax error: Unterminated quoted string
When I use v3.21.11_trt8.0_x86 version
./tao-converter: 1: ELF: not found
./tao-converter: 1: : not found
./tao-converter: 2: @:@J@888: not found
./tao-converter: 3: �: not found
./tao-converter: 4: Syntax error: ")" unexpected
How about
$ ./tao-converter -h
codeinside@CI-1442:~/deepstream_lpr_app$ sudo sh ./tao-converter -h
codeinside@CI-1442:~/deepstream_lpr_app$ sudo sh ./tao-converter_8 -h
./tao-converter_8: 7: Syntax error: Unterminated quoted string
Can you remove “sh” ?
codeinside@CI-1442:~/deepstream_lpr_app$ sudo ./tao-converter_8 -h
sudo: ./tao-converter_8: command not found
codeinside@CI-1442:~/deepstream_lpr_app$ ./tao-converter_8 -h
bash: ./tao-converter_8: Permission denied
Please
$ chmod +x tao-converter*
This fixed ./tao-converter -h. But I have the same error:
usage: ./tao-converter_8 [-h] [-e ENGINE_FILE_PATH]
	[-k ENCODE_KEY] [-c CACHE_FILE]
	[-o OUTPUTS] [-d INPUT_DIMENSIONS]
	[-b BATCH_SIZE] [-m MAX_BATCH_SIZE]
	[-w MAX_WORKSPACE_SIZE] [-t DATA_TYPE]
	[-i INPUT_ORDER] [-s] [-u DLA_CORE]
	input_file
Generate TensorRT engine from exported model
positional arguments:
  input_file		Input file (.etlt exported model).
required flag arguments:
  -d		comma separated list of input dimensions(not required for TLT 3.0 new models).
  -k		model encoding key.
optional flag arguments:
  -b		calibration batch size (default 8).
  -c		calibration cache file (default cal.bin).
  -e		file the engine is saved to (default saved.engine).
  -i		input dimension ordering -- nchw, nhwc, nc (default nchw).
  -m		maximum TensorRT engine batch size (default 16). If meet with out-of-memory issue, please decrease the batch size accordingly.
  -o		comma separated list of output node names (default none).
  -p		comma separated list of optimization profile shapes in the format <input_name>,<min_shape>,<opt_shape>,<max_shape>, where each shape has `x` as delimiter, e.g., NxC, NxCxHxW, NxCxDxHxW, etc. Can be specified multiple times if there are multiple input tensors for the model. This argument is only useful in dynamic shape case.
  -s		TensorRT strict_type_constraints flag for INT8 mode(default false).
  -t		TensorRT data type -- fp32, fp16, int8 (default fp32).
  -u		Use DLA core N for layers that support DLA(default = -1, which means no DLA core will be utilized for inference. Note that it'll always allow GPU fallback).
  -w		maximum workspace size of TensorRT engine (default 1<<30). If meet with out-of-memory issue, please increase the workspace size accordingly.
codeinside@CI-1442:~/deepstream_lpr_app$ sudo sh ./tao-converter_8 -k nvidia_tlt -p image_input,1x3x48x96,4x3x48x96,16x3x48x96            models/LP/LPR/us_lprnet_baseline18_deployable.etlt -t fp16 -e models/LP/LPR/us_lprnet_baseline18_deployable.etlt_b16_gpu0_fp16.engine
Please type the command again. Not directly copy something from website to avoid unexpected string.
