Deepstream Memory Leak and FPS drop on Jetson
  1. which DeepStream sample are you testing or referring to? could you share the code diff if you modify the code? without any code and cfg modification, can you reproduce this issue? wondering if it is related to the new modifications.
  2. please refer to this topic . can you provide more logs by nvmemstat ? it can save the memory usage at intervals. can you provide more valgrind logs by this method vagrid , it can give memory details.
