• Hardware Platform: GPU
• DeepStream Version: 6.2
• TensorRT Version 8502
• NVIDIA GPU Driver Version (valid for GPU only) 525.58
• Issue Type( questions, new requirements, bugs) bug
I am facing an issue of :
nvbufsurface: NvBufSurfaceCopy: batch size doesn’t match
Here is my pipeline:
multisrcbin → stream_muxer → triton_server → nvvidconv → capsfilter → nvtiler → nvosd → nvvidconv2 → queue → nvv4l2h264enc → rtph264pay → udpsink
- I give multiple input sources and tile them after inference and pass through
rtsp/filesink
. - When I use
filesink
with appropriate encoder and parser it works fine. - But when I use
rtsp
I am facing the above issue atnvv4l2h264enc
I understand it means input and output batch size for NvBufSurfaceCopy
is not matching. However, I don’t understand why it’s happening.
If I run it with single source, it works fine, but not with more than one. Ideally after nvtiler
irrespective of number of input sources the output batch size should be 1 right? Then why this error?
Thanks,
Pavan MV
