Deepstream on CPU
Hardware Platform (Jetson / GPU) : NVIDIA A2
• DeepStream Version : 6.3
• TensorRT Version : 12.2
• NVIDIA GPU Driver Version (valid for GPU only) : 535.146.02
Can I run deepstream_test3.py on CPU instead of GPU?
Why do you want to run the DeepStream sample on CPU?
The whole DeepStream SDK is based on Nvidia GPU. If you don’t want GPU, please refer to other resources.
I am building object oriented code and I am building CI pipeline on cloud and unit tests so I need to run unit tests on CPU not GPU but for production I will use GPU for sure
DeepStream doesn’t support non-GPU inferencing.
