I have a Jetson Nano B01. I am running Jetpack 4.61.
I am trying to install Deepstream 6 using the deepstream-6.0_6.0.1-1_arm64.deb file following the instructions at Deepstream 6.0.1 quickstart
I have checked that the correct version of jetpack is installed.
Hi @Amycao ,
Thank you for the reply - greatly appreciated.
I have just reinstalled using the deepsteam_sdk_v6.0.1_jetson.tbz2 tar ball. This worked.
I use an SSH terminal for convenience and sometimes forget that I am in an SSH terminal.
When I run :
No EGL Display
nvbufsurftransform: Could not get EGL display connection
cdann@nano461:/opt/nvidia/deepstream/deepstream-6.0/samples$ gst-inspect-1.0 nvstreammux
No EGL Display
This is expected but it seems to corrupt the config and I continue to get the ‘src_bin_muxer’ error even from the GUI console.
If I rerun the sudo /opt/nvida/deepstream/deepstream-6.0/install.sh script and sudo ldconfig and then run from the GUI console it works.
