Deepstream-opencv-test sample app is considerably slower than gst-launch pipeline
PC: RTX 2070 Super
Deepstream: 6.2
Driver Version: 525.105.17
Docker image: deepstream:6.2-devel
I am trying to run the sample app deepstream-opencv-test. I have read the instructions and installed gst-dsexample as needed. Afterwards I build deepstream-opencv-test and everything works as expected, with the bounding boxes being blurred. However the fps is quite low. I then change the eglsink to a fake sink, and use the video file /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
  if(prop.integrated) {
    sink = gst_element_factory_make ("nv3dsink", "nvvideo-renderer");
  } else {
    //sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
    sink = gst_element_factory_make ("fakesink", "fake-renderer");
this particular video takes about 60 seconds to complete with fake sink.
However if I create the pipeline using gst-launch with the same video and same pgie, it only takes 10 seconds to complete.
gst-launch-1.0 filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 ! qtdemux ! h264parse ! nvv4l2decoder ! m.sink_0 nvstreammux name=m batch-size=1 width=1280 height=720 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-opencv-test/dsopencvtest_pgie_config.txt ! nvvideoconvert nvbuf-memory-type= nvbuf-mem-cuda-unified  ! 'video/x-raw(memory:NVMM), format=RGBA' ! dsexample full-frame=0 blur-objects=1 ! nvdsosd ! fakesink
Thus i’m curious how the c++ pipeline is quite slow.
Could you try to set the same resolution of nvstreammux and same memory type of nvvideoconvert and comment on the probe of the source code?
After setting the same resolution, there was some improvement. However the major factor was the memory type. The gst-launch uses nvbuf-mem-cuda-unified, but the sample code uses nvbuf-mem-cuda-pinned. After changing the sample code to use nvbuf-mem-cuda-unified, the pipeline execution time is the same. Thank you very much.
