• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
Jetson Xavuer nx
deepstream 5.0
tensorrt7.0
jetpack4.4
hello experts, my code is here
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break #frame_number = frame_meta.frame_num #num_rects = frame_meta.num_obj_meta
l_obj=frame_meta.obj_meta_list
#lines = []
display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
obj_index = 0
line_index = 0
while l_obj is not None:
#index = 0
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
#for i in cocopair:
# if i[0] == obj_index:
# temp = l_obj
line = display_meta.line_params
# for a in range(i[1]-i[0]):
# if not temp:
# temp=temp.next
line[line_index].x1 = 0
line[line_index].y1 = 0
line[line_index].x2 = line_index
line[line_index].y2 = line_index
line[line_index].line_width = 6
line[line_index].line_color.set(1.0, 0.0, 0.0,0.5)
line_index += 1
obj_index += 1
print("obj inedx",obj_index)
break
#obj_counter[obj_meta.class_id] += 1
try:
l_obj=l_obj.next
break
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame=l_frame.next
break
return Gst.PadProbeReturn.OK
i want to draw skeleton based on the keypoints, but there is no line, and when there are more than 17 obj, an index error occured
File “test.py”, line 88, in osd_sink_pad_buffer_probe
IndexError: list index out of range
can u tell me how to draw lines with python, and circles,now i use small rectange to replace circle, how to draw circles with object detector?
try:
# it alone.
break
#lines = []
display_meta.num_lines = 17
line_params = display_meta.line_params
#obj_index = 0
line_index = 0
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
for i in range(17):
if cocopair[i][0]==obj_meta.class_id:
temp = l_obj
while temp is not None:
temp_meta = pyds.NvDsObjectMeta.cast(temp.data)
temp=temp.next
if temp_meta.class_id == cocopair[i][1]:
line_params[line_index].x1 = int(obj_meta.rect_params.left)
line_params[line_index].y1 = int(obj_meta.rect_params.top)
line_params[line_index].x2 = int(temp_meta.rect_params.left)
line_params[line_index].y2 = int(temp_meta.rect_params.top)
line_params[line_index].line_color.set(i, 0, 0, 0.5)
line_params[line_index].line_width = 4
line_index+=1
l_obj=l_obj.next
try:
break
yes, i can draw the line now.
but now i want to evaluate the fps with camera. can u tell me how to evaluate the fps of inference with python.
i tried to evaluate fps in osd function like this
if frame_meta.bInferDone:
time = (cv.getTickCount() - t) / cv.getTickFrequency()
fps = 1.0 / time
print(“this frame is inferenced, fps: {}”.format(fps))
else:
print("this frame not inferenced ")
try:
break
if l_frame is not None:
t = cv.getTickCount()
but its not correct. the result is likethis frame is inferenced, fps: 0.00015717842572132173
fine i find the solution but i dont know if its correct, i evalute the fps in the customer post-processing function. like this
static long tim = 0;
bool NvDsInferParseCustomResnet (std::vector const &outputLayersInfo,
NvDsInferNetworkInfo const &networkInfo,
NvDsInferParseDetectionParams const &detectionParams,
std::vector &objectList)
//std::cout<<“in customer defined function”<<std::endl;
/* Find the output layer */
static int outputLayerIndex = -1;
//static int outputLayer_L1Index = -1;
//static int outputLayer_L2Index = -1;
long cur_time = cv::getTickCount();
double fps = 1.0 /((cur_time - tim) / cv::getTickFrequency());
tim = cur_time;
std::cout<<"fps: "<<fps<<std::endl;
