I see you run with deepstream 6.0 already. we do not have 6.0EA container published until now.
Since we have different result using the same code, I guess it may result in the env difference.Can we use a same docker run the code,for example the docker for deepstream 5.1?Or what can I do to reach a same result as you? Thank you.
We do not fix in older version, so you can wait until 6.0 docker online.
OK, When will the docker for 6.0 be available?
Around end of Oct 2021.
nice! thank you.Hope for your release.
