• Hardware Platform (Jetson / GPU) : NVIDIA Jetson AGX Orin
• DeepStream Version : 6.3
• JetPack Version (valid for Jetson only) : 5
• TensorRT Version : 8.5.2
• Issue Type( questions, new requirements, bugs) : questions
I have an ONNX model that outputs 224x224x1 mask in segmentation task. Here is the screen from Netron:
During the execution of the Python DeepStream code, I display the video on the screen and print the mask shape in the terminal. The mask shape is incorrectly returned as 224x1 instead of 224x224x1. Due to that I cannot display the mask on the display. What could be causing this issue? Unfortunately, I cannot provide the model itself. I tried to run the python example of deepstream-segmentation and the mask shape there has 512x512 shape.
Here is the output from terminal:
Here is the configuration file:
[property]
gpu-id=0
# 0=RGB, 1=BGR
model-color-format=0
onnx-file=my_onnx_model.onnx
model-engine-file=my_engine_model.engine
infer-dims=3;224;224
batch-size=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=0
num-detected-classes=1
interval=0
gie-unique-id=1
network-type=2
segmentation-threshold=0.3
Here is my Python code:
def osd_sink_pad_buffer_probe(pad, info, u_data):
gst_buffer = info.get_buffer()
if not gst_buffer:
print("Unable to get GstBuffer ")
return
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
try:
except StopIteration:
break
frame_num = frame_meta.frame_num
print("Frame Number:", frame_num)
l_user = frame_meta.frame_user_meta_list
while l_user is not None:
try:
seg_user_meta = pyds.NvDsUserMeta.cast(l_user.data)
break
if (
seg_user_meta
and seg_user_meta.base_meta.meta_type
== pyds.NVDSINFER_SEGMENTATION_META
try:
# Note that seg_user_meta.user_meta_data needs a cast to pyds.NvDsInferSegmentationMeta
segmeta = pyds.NvDsInferSegmentationMeta.cast(
break
# Retrieve mask data in the numpy format from segmeta
masks = pyds.get_segmentation_masks(segmeta)
masks = np.array(masks, copy=True, order="C")
print("masks shape:", masks.shape)
try:
l_user = l_user.next
break
try:
l_frame = l_frame.next
break
return Gst.PadProbeReturn.OK
def main(args):
# Check input arguments
if len(args) < 2:
sys.stderr.write("usage: %s <h264_elementary_stream>\n" % args[0])
sys.exit(1)
# GStreamer initialization
Gst.init(None)
## CREATE GSTREAMER ELEMENTS
# Pipeline element that will form a connection of other elements
print("Creating Pipeline\n")
pipeline = Gst.Pipeline()
if not pipeline:
sys.stderr.write("Unable to create Pipeline")
# Source elemment for reading from the file
print("Creating Source\n")
source = Gst.ElementFactory.make("filesrc", "file-source")
if not source:
sys.stderr.write("Unable to create Source")
# Data fromat is elementaty h264 steam, we need h264parser
print("Creating H264Parser\n")
h264parser = Gst.ElementFactory.make("h264parse", "h264-parser")
if not h264parser:
sys.stderr.write("Unable to create H264Parser")
# use nvdec for hardware accelerated decode on GPU
print("Creating Decoder\n")
decoder = Gst.ElementFactory.make("nvv4l2decoder", "nvv4l2-decoder")
if not decoder:
sys.stderr.write("Unable to create Nvv4l2 Decoder")
# Create nvstreammux instance to form batches from one or more sources.
print("Creating Streammux\n")
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
sys.stderr.write(" Unable to create NvStreamMux \n")
# Create segmentation for primary inference
print("Creating Segmentation\n")
seg = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not seg:
sys.stderr.write("Unable to create primary inferene\n")
# Create nvvideoconvert to convert from NV12 to RGBA as required by nvosd
print("Creatting nvvideoconvert\n")
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "nvvideconvert")
if not nvvidconv:
sys.stderr.write(" Unable to create nvvideoconvert \n")
# Create OSD to draw on the converted RGBA buffer
print("Creating OSD")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
if not nvosd:
sys.stderr.write(" Unable to create nvosd \n")
# Create nv3dsink for output
print("Creating nv3dsink \n")
sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
if not sink:
sys.stderr.write("Unable to create nv3dsink \n")
print("Playing file %s " % args[1])
source.set_property("location", args[1])
streammux.set_property("width", 1920)
streammux.set_property("height", 1080)
streammux.set_property("batch-size", 1)
streammux.set_property("batched-push-timeout", 4000000)
seg.set_property("config-file-path", "config_infer_primary.txt")
# Set sync = false to avoid late frame drops at the display-sink
sink.set_property("sync", False)
print("Adding element to Pipeline\n")
pipeline.add(source)
pipeline.add(h264parser)
pipeline.add(decoder)
pipeline.add(streammux)
pipeline.add(seg)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
# pipeline.add(nvsegvisual)
pipeline.add(sink)
# link elements together
# file-source -> h264-parser -> nvv4l2-decoder -> nvinfer -> nvvideconvert -> nvosd -> nvsegvisual -> sink
print("Linking elements in the Pipeline\n")
source.link(h264parser)
h264parser.link(decoder)
sinkpad = streammux.get_request_pad("sink_0")
if not sinkpad:
sys.stderr.write("Unable to get the sink pad of streammux")
srcpad = decoder.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to get source pad of decoder")
srcpad.link(sinkpad)
streammux.link(seg)
seg.link(nvvidconv)
nvvidconv.link(nvosd)
nvosd.link(sink)
# create an event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
bus.connect("message", bus_call, loop)
osdsinkpad = nvosd.get_static_pad("sink")
if not osdsinkpad:
sys.stderr.write(" Unable to get sink pad of nvosd \n")
osdsinkpad.add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, 0)
print("Starting pipeline \n")
# start play back and listen to events
pipeline.set_state(Gst.State.PLAYING)
try:
loop.run()
except:
pass
# cleanup
pipeline.set_state(Gst.State.NULL)
