Deepstream-parallel-infer-app:when one of the stream is disconnected, the stored video and image are inconsistent
There should be no problem with saving images, and we have no experience with saving videos in the probe function. About the wrong match issue, we are investigating a similar issue 290327.
export USE_NEW_NVSTREAMMUX=yes
Thanks, it worked. However, after using new streammux, when one video stream is disconnected, the performance will be greatly reduced. What is the reason? The following figures show the performance comparison before and after disconnecting the video stream.
You can refer to our FAQ to debug some parameters for new nvstreammux and see whether the result improves.
