Deepstream_parallel_inference_app add rtsp reconnects
The pipeline of the parallel is more complicated than the deepstream-app. We’ll take a deep dive into this issue.
At present, there are the following two methods you can refer to.
1.use the udp mode of the rtspsrc
2.modify the source code of gstrtspsrc.c to block the EOS message and replace the /usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstrtsp.so in your environment
Okay, I will test the second method. Thank you.
