DeepStream Pause, Resume implementation
I was wondering where I can find the implementation of Pause, Resume in the deep stream pipeline? Since when I run the pipeline I see in the output that press P for pause press R for resume. I would like to find the code in which this is implemented and rather than keystroke change it to a signal that I define myself.
Mahshid
Hi @MGh
In the Deepstream C++ sample app, there is event_thread_func named function to do this. In the main function, this thread function added before g_main_loop_run:
g_timeout_add (40, event_thread_func, NULL);
g_main_loop_run (main_loop);
In event_thread_func, this implementation is at the end of the function in the switch-case statement
static guint rrow, rcol;
static gboolean rrowsel = FALSE, selecting = FALSE;
 * Loop function to check keyboard inputs and status of each pipeline.
static gboolean
event_thread_func (gpointer arg)
  guint i;
  gboolean ret = TRUE;
  // Check if all instances have quit
  for (i = 0; i < num_instances; i++) {
    if (!appCtx[i]->quit)
      break;
  if (i == num_instances) {
    quit = TRUE;
    g_main_loop_quit (main_loop);
    return FALSE;
  // Check for keyboard input
  if (!kbhit ()) {
    //continue;
    return TRUE;
  int c = fgetc (stdin);
  g_print ("\n");
  gint source_id;
  GstElement *tiler = appCtx[0]->pipeline.tiled_display_bin.tiler;
  g_object_get (G_OBJECT (tiler), "show-source", &source_id, NULL);
  if (selecting) {
    if (rrowsel == FALSE) {
      if (c >= '0' && c <= '9') {
        rrow = c - '0';
        if (rrow < appCtx[0]->config.tiled_display_config.rows){
          g_print ("--selecting source  row %d--\n", rrow);
          rrowsel = TRUE;
        }else{
          g_print ("--selected source  row %d out of bound, reenter\n", rrow);
    } else {
        unsigned int tile_num_columns = appCtx[0]->config.tiled_display_config.columns;
        rcol = c - '0';
        if (rcol < tile_num_columns){
          selecting = FALSE;
          rrowsel = FALSE;
          source_id = tile_num_columns * rrow + rcol;
          g_print ("--selecting source  col %d sou=%d--\n", rcol, source_id);
          if (source_id >= (gint) appCtx[0]->config.num_source_sub_bins) {
            source_id = -1;
          } else {
            source_ids[0] = source_id;
            appCtx[0]->show_bbox_text = TRUE;
            g_object_set (G_OBJECT (tiler), "show-source", source_id, NULL);
        }else{
          g_print ("--selected source  col %d out of bound, reenter\n", rcol);
  switch (c) {
    case 'h':
      print_runtime_commands ();
      break;
    case 'p':
        pause_pipeline (appCtx[i]);
      break;
    case 'r':
        resume_pipeline (appCtx[i]);
      break;
    case 'q':
      quit = TRUE;
      ret = FALSE;
      break;
    case 'z':
      if (source_id == -1 && selecting == FALSE) {
        g_print ("--selecting source --\n");
        selecting = TRUE;
      } else {
        if (!show_bbox_text)
          appCtx[0]->show_bbox_text = FALSE;
        g_object_set (G_OBJECT (tiler), "show-source", -1, NULL);
        source_ids[0] = -1;
        selecting = FALSE;
        g_print ("--tiled mode --\n");
      break;
    default:
      break;
  return ret;
Regards
Hi @mehmetdeniz,
Thanks a lot. This is what I was looking for.
Regards
Mahshid
