DeepStream Pose Classification predictions are highly biased towards Walking
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.3
• JetPack Version (valid for Jetson only) 5.1.1
• TensorRT Version 8.5.2
• Issue Type( questions, new requirements, bugs) Questions
Hi, I am running a DeepStream Pose Classification pipeline on Jetson device. I tested it on tons of videos . For every video the prediction is always "Walking irrespective of the person performing any other activity ( For eg - Sitting, Standing).
I have even tried to change the value of frame-sequence-length starting from min value of 3 to max value of 300 in steps of 10 in config_preprocess_bodypose_classification.txt. Even though after testing it for difference sequence the prediction is always walking.
[user-configs]
#actual sequence length of frames
frames-sequence-length=300
I am attaching the snapshot of the video in which person is sitting for entire video. Even though for this video the prediction is walking with around 70% confidence.
Q1. Can Anyone Let me know what are configurable parameters in the DeepStream PoseClassification Pipeline which would help to achieve the desired accuracy as it is mentioned on the Pose Classification NGC Catalog ?https://catalog.ngc.nvidia.com/orgs/nvidia/teams/tao/models/poseclassificationnet
Q2 When we had clearly mentioned frame-sequence-length to be of N frames ( N can be 30. 60, 90 etc till max 300). Then why are predicitions happening for every frame instead of happening for set of frames as mentioned in frame-sequence-length?
We are investigating the topic. Seems the output of the bodypose3d model BodyPose3DNet | NVIDIA NGC does not match the input of the pose classification model. Pose Classification | NVIDIA NGC
Thanks @Fiona.Chen for your response.
Please inform us once it has been resolved.
Hi @Fiona.Chen . May I know if the issue has been resolved ?
It would be great if you can provide an update on the same.
There are two items impacting the precision of the pretrained pose classifier inferencing result.
  1. The pre-trained pose classifier model Pose Classification | NVIDIA NGC is trained by the 3d pose key points which are in the relative coordinate system, but the sample calculate the BodyPose3DNet | NVIDIA NGC key points in the camera coordinate system. So the pose classifier did not inference correctly. I’ve change the code in deepstream_tao_apps/apps/tao_others/deepstream-pose-classification/deepstream_pose_classification_app.cpp at master · NVIDIA-AI-IOT/deepstream_tao_apps (github.com) to correct the coordinates.
    If you train the Pose Classification | NVIDIA NGC by yourself, please pay attention to the coordinates system. You need to make sure the input key points use the same coordinate system as the training key points when you do the inferencing.
  2. The pre-trained BodyPose3DNet | NVIDIA NGC model is not precise enough. Sometimes the model does not output correct pose key points. The Pose Classification | NVIDIA NGC model needs successive pose key points to do the inferencing, the unstable key points may cause the wrong inferencing result from the pose classifier model. You may re-train the BodyPose3DNet | NVIDIA NGC model or use other bodypose 3d models to get more precise and stable output.
Moving to TAO forum.
Hi @Fiona.Chen , Thanks for the reply. Yes I agree that the BodyPose3d output is quite unstable so I have gone through all the resources regarding Tao toolkit for BodyPose3dNet but I didn’t find any training scripts for it.
Could you please share more information on how we can train it?
Thanks and looking forward to your reply .
Has the bias toward walking disappeared to some extent after making the correction?
The suggestion is to find another bodypose3d model. The trainning scripts of BodyPose3DNet | NVIDIA NGC is not open source now.
