Deepstream preprocess element output seems to be the same as input
**• Hardware Platform: GPU
**• DeepStream Version: 6.4
**• NVIDIA GPU Driver Version: 535.104.12
**• Issue Type: question/bug
**• How to reproduce the issue ?
When analyzing preprocess element output, using a probe function on the preprocess src pad - it seems the frame size remains the same as the input - or, if we are looking in the wrong place, where should we see the reshaped frame?
  • Based on DS python apps/deepstream-preprocess-test
  • Preprocess width and hight config remains as default: 960, 544
  • running command:
python3 deepstream_preprocess_test_custom.py -i file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
in the preprocess src probe function:
data_type, shape, strides, dataptr, size = pyds.get_nvds_buf_surface_gpu(hash(gst_buffer), frame_meta.batch_id)
> shape=(1080, 1920, 4)
Although we expect it to be 544x960x4 . is that right?
*in order to use get_nvds_buf_surface_gpu() we must to add conversion to RGBA to this pipeline:
nvvidconv0 = Gst.ElementFactory.make(“nvvideoconvert”, “convertor0”)
filter0 = Gst.ElementFactory.make(“capsfilter”, “filter0”)
caps1 = Gst.Caps.from_string(“video/x-raw(memory:NVMM), format=RGBA”)
filter0.set_property(“caps”, caps1)
We do not transform the original image data in the Gstbuffer. It’s scaled in the preprocess plugin. If you want to get the scaled image, you can use the dump_rois in the gstnvdspreprocess.cpp.
