The following error happens after running the app for a few hours:
GStreamer-CRITICAL **: 22:04:01.099: gst_memory_get_sizes: assertion 'mem != NULL' failed
deepstream_cpp exited with code 139
Debugging Info
My pipeline is created using the following _make_pipeline() function:
def _make_pipeline(self, pipeline):
streammux = self._make_element("nvstreammux", "stream-muxer")
pipeline.add(streammux)
is_live = False
for i in range(len(self.source_inputs)):
print("Creating source_bin ", i, " \n ", flush=True)
uri_name = self.source_inputs[i]
if uri_name.find("rtsp://") == 0:
is_live = True
source_bin = self._create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname = f"sink_{i:.0f}"
sinkpad = streammux.get_request_pad(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
q1 = self._make_element("queue", "queue1")
q2 = self._make_element("queue", "queue2")
pgie = self._make_element("nvinfer", "primary-inference")
nvtracker = self._make_element("nvtracker", "tracker")
nvdsanalytics = self._make_element("nvdsanalytics", "nvdsanalytics")
tee = self._make_element("tee", "tee")
tiler = self._make_element("nvmultistreamtiler", "nvtiler")
nvvidconv = self._make_element("nvvideoconvert", "convertor")
nvosd = self._make_element("nvdsosd", "onscreendisplay")
sink = self._make_element("nveglglessink", "nvvideo-renderer")
appsink = self._make_element("appsink", "appsink")
# setting elements properties
streammux.set_property('width', self.muxer_shape[0])
streammux.set_property('height', self.muxer_shape[1])
streammux.set_property('batch-size', len(self.source_inputs))
streammux.set_property('batched-push-timeout', 40000)
if is_live:
print("Atleast one of the sources is live", flush=True)
streammux.set_property('live-source', 1)
pgie.set_property('config-file-path', self.pgie_config_path)
pgie_batch_size = pgie.get_property("batch-size")
if (pgie_batch_size != len(self.source_inputs)):
print("WARNING: Overriding infer-config batch-size", pgie_batch_size,
" with number of sources ", len(self.source_inputs), " \n", flush=True)
pgie.set_property("batch-size", len(self.source_inputs))
self._set_tracker_properties(nvtracker)
nvdsanalytics.set_property("config-file", self.analytics_config_path)
tiler_rows=int(math.sqrt(len(self.source_inputs)))
tiler_columns=int(math.ceil((1.0*len(self.source_inputs))/tiler_rows))
tiler.set_property("rows", tiler_rows)
tiler.set_property("columns", tiler_columns)
tiler.set_property("width", 1280)
tiler.set_property("height", 720)
sink.set_property("qos", 0)
sink.set_property("sync", False)
nvosd.set_property('process-mode', 2)
nvosd.set_property('display-text', 1)
appsink.set_property("emit-signals", True)
appsink.set_property("async", True)
appsink.set_property("sync", False)
# adding elements to pipeline; order doesn't matter.
pipeline.add(q1)
pipeline.add(q2)
pipeline.add(pgie)
pipeline.add(nvtracker)
pipeline.add(nvdsanalytics)
pipeline.add(tee)
pipeline.add(tiler)
pipeline.add(nvvidconv)
pipeline.add(nvosd)
pipeline.add(sink)
pipeline.add(appsink)
print("Linking elements in the Pipeline \n", flush=True)
# streammux > pgie > nvtracker > analytics > nvvidconv > tee > q1 > tiler > nvosd > sink
# `>>> q2 > appsink
streammux.link(pgie)
pgie.link(nvtracker)
nvtracker.link(nvdsanalytics)
nvdsanalytics.link(nvvidconv)
nvvidconv.link(tee)
# linking tee
tee_srcpad_renderer = tee.get_request_pad("src_0")
tee_srcpad_appsink = tee.get_request_pad("src_1")
if not tee_srcpad_renderer or not tee_srcpad_appsink:
q1_sinkpad = q1.get_static_pad("sink")
q2_sinkpad = q2.get_static_pad("sink")
if not q1_sinkpad or not q2_sinkpad:
tee_srcpad_renderer.link(q1_sinkpad)
tee_srcpad_appsink.link(q2_sinkpad)
q1.link(tiler)
tiler.link(nvosd)
nvosd.link(sink)
q2.link(appsink)
# attaching cb function to appsink samples
appsink.connect("new-sample", self._appsink_cb, None)
return pipeline
other info
I ran the app with 20 rtsp sources.
important note
This has also occurred using deepstream-test3 app with the same 20 rtsp sources.
However, deepstream-app with the same 20 rtsp sources ran for days without raising any errors.
GPU
• DeepStream Version
5.1
• TensorRT Version
I am using the deepstream devel docker image.
465.19.01
questions
