• Hardware Platform (Jetson / GPU): Jetson Nano
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4
• TensorRT Version: 7
• Issue Type( nvmsgborker, new requirements, bugs): why nvmsgbroker set my connection string with bootstrap at the end? even though I didn’t give bootstrap anywhere.
I trying to create a pipeline who will render the output on RTSP and send meta data through kafka broker.
The RTSP part work well , but kafka broker didn’t work. pipeline could not establish the connection with my the backend server.
%3|1610977664.902|FAIL|rdkafka#producer-1| [thrd:192.168.0.4:2181/bootstrap]: 192.168.0.4:2181/bootstrap: Receive failed: Disconnected
%3|1610977664.902|ERROR|rdkafka#producer-1| [thrd:192.168.0.4:2181/bootstrap]: 192.168.0.4:2181/bootstrap: Receive failed: Disconnected
%3|1610977664.902|ERROR|rdkafka#producer-1| [thrd:192.168.0.4:2181/bootstrap]: 1/1 brokers are down
The cofiguration for kafka are
‘IP’:“192.168.0.4”,
‘port’:‘2181’,
‘topic’:‘jetson-topic’,
‘schema_type’ : 0,
‘msconv_cfg_file’: “configurations/dstest4_msgconv_config.txt”,
‘proto_lib’: ‘/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_kafka_proto.so’
I don#t know why nvmsgbroker use bootstrap it where it come from.
