• Hardware Platform (Jetson Nano)
• DeepStream Version 5.0
• JetPack Version 4.4
• Issue Type: Question
Hello everyone!
So I am running a custom deepstream python application (derived from deepstream_imagedata and deepstream_tracker applications) on the Jetson, which is really computationally expensive and I would like to run it without the video output. I googled around and discovered that I could do that by typing “unset DISPLAY” into the terminal before starting my python application. The problem is: I have to unset the display environment variable before I can run my application every single time I open a new terminal. Is there a way to unset the variable permanently? I tried looking for the environment variable in the /etc/environment file but the only variable in that file was the “PATH” variable.
Thanks in advance.
