I had trouble installing the deepstream python clients. I have Jetson Orin Nano, Jetpack 5.1.2, Deepsream 6.3. Running the first python client fails to import pyds. What is that?
I also tried running gst-python autogen.sh, and it said:
Please get the right tools before proceeding.
Alternatively, if you’re sure we’re wrong, run with --nocheck.
Can the deepstream-test1 native app run normally ?
It the native app work fine. please check if the dependencies are installed successfully.
You can try the following command line In README.md.
