Deepstream Python error - Custom Parse Function not found on InstanceSegment-postprocessor
• Hardware Platform (Jetson / GPU) Jetson Orin
• DeepStream Version 6.1
• JetPack Version (valid for Jetson only) 5.01
• TensorRT Version 8.4
• NVIDIA GPU Driver Version (valid for GPU only) 11.4
• Issue Type( questions, new requirements, bugs) question
Hi
I created an MRCNN custom model using the TAO toolkit. The model trained and produced good results. I exported the model and then on Orin I converted successfully and produced the engine file.
I also built the plugin module using the TensorRT instructions (including the updated version of CMake). During this process I noticed the following:
  1. I used a GPU capability of 87 for the Orin machine and obtained this from the device query:
./deviceQuery Starting…
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: “Orin”
CUDA Driver Version / Runtime Version 11.4 / 11.4
CUDA Capability Major/Minor version number: 8.7
Total amount of global memory: 30623 MBytes (32110190592 bytes)
(016) Multiprocessors, (128) CUDA Cores/MP: 2048 CUDA Cores
GPU Max Clock rate: 1300 MHz (1.30 GHz)
Memory Clock rate: 1300 Mhz
Memory Bus Width: 128-bit
L2 Cache Size: 4194304 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total shared memory per multiprocessor: 167936 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Managed Memory: Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 0 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 11.4, CUDA Runtime Version = 11.4, NumDevs = 1
Result = PASS
  1. Building the updated plugin lib did not create the “out” directory, but did compile the library libnvinfer_plugin.so.8.4.1, which is the file i used to copy to /usr/lib/aarch64-linux…
Running ll libnvinfer_plugin* yields the following:
lrwxrwxrwx 1 root root 26 Jul 10 09:07 libnvinfer_plugin.so → libnvinfer_plugin.so.8.4.1*
lrwxrwxrwx 1 root root 26 Jul 9 20:27 libnvinfer_plugin.so.8 → libnvinfer_plugin.so.8.4.1*
-rwxr-xr-x 1 root root 26739504 Jul 10 10:41 libnvinfer_plugin.so.8.4.1*
-rw-r–r-- 1 root root 30558374 Apr 30 18:43 libnvinfer_plugin_static.a
Which I believe is correct.
My problem is that when I try to use the engine (in a Python pipeline used before) I get the following error:
ERROR nvinfer gstnvinfer.cpp:640:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initResource() <nvdsinfer_context_impl.cpp:862> [UID = 1]: Custom parse function not found for InstanceSegment-postprocessor
I am able to successfully run the deepstream_tao sample apps and also ran trtexec on the engine file and that passed.
Any help gratefully received - cheers
from the error, you did not set parse-bbox-instance-mask-func-name ,please find it in Gst-nvinfer — DeepStream 6.1.1 Release documentation
Thank you @fanzh
Actually I have that entry in my config file:
[property]
gpu-id=0
model-color-format=0
net-scale-factor=0.017507
parse-bbox-instance-mask-func-name=NvDsInferParseCustomMrcnnTLT
network-type=3
#tlt-encoded-model=…/Models/save/model.etlt
model-engine-file=…/Models/save/model.etlt_b1_gpu0_int8.engine
labelfile-path=…/Models/save/labels.txt
int8-calib-file=…/Models/save/maskrcnn.bin
offsets=123.675;116.28;103.53
infer-dims=3;1024;1024
tlt-model-key=nvidia_tlt
network-type=3
num-detected-classes=2
uff-input-order=0
output-blob-names=generate_detections;mask_fcn_logits/BiasAdd
uff-input-blob-name=Input
maintain-aspect-ratio=0
output-tensor-meta=0
num-detected-classes=1
batch-size=1
0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
interval=0
gie-unique-id=1
#no cluster
0=Group Rectangles, 1=DBSCAN, 2=NMS, 3= DBSCAN+NMS Hybrid, 4 = None(No clustering)
MRCNN supports only cluster-mode=4; Clustering is done by the model itself
cluster-mode=4
output-instance-mask=1
[class-attrs-all]
pre-cluster-threshold=0.8
Do I have the correct lib and installed correctly? (libnvinfer_plugin.so.8.4.1)
you did not set custom-lib-path, please refer to deepstream sample deepstream-mrcnn-test.
and nvinfer plugin is opensource, you can add logs to debug, you can find that error in function InstanceSegmentPostprocessor::initResource.
thak you @fanzh , I ended up using the TAO specific plugin together with the TLT2 bbox function and all was good. I’ve marked this as the solution.
