htopcu
#1
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.5.1
• TensorRT Version 7.1.3+cuda10.2
• Issue Type( questions, new requirements, bugs) Question
How can I flip usb cam with python?
For 180-degree rotation, you can use dsexample plugin. Please refer to
/opt/nvidia/deepstream/deepstream-5.1/sources/gst-plugins/gst-dsexample/README
For USB camera source, please check
deepstream_python_apps/apps/deepstream-test1-usbcam at master · NVIDIA-AI-IOT/deepstream_python_apps · GitHub
A possible solution:
- Make sure you can run deepstream-test1-usbcam with your camera
- Implement 180-degree rotation in dsexample with NvBufSurface APIs
- Customize deepstream-test1-usbcam to link with dsexample:
... ! nvvideoconvert ! dsexample ! nvstreammux ! ...
This uses hardware engine for rotation and requires much customization.
For software solution, you can use videoflip plugin: videoflip
It should work by linking like:
... ! videoconvert ! videoflip ! nvvideoconvert ! nvstreammux ! ...
htopcu
#4
Thank you. I will try as soon as possible.
system
closed
#6
