I’m working with deepstream python 5.1 test4, and I want to change the timestamp format to unix time, for example, 1626370468.
The default timestamp format is like %Y-%m-%dT%H:%M:%S.%.3dZ, defined in pyds.so.
How can I modify the format?
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
User would need to come up with a string for the format they need and put it in the timestamp buffer - nvds event message data.
FYI - We will be open sourcing the bindings in an upcoming release.
