• Hardware Platform (Jetson / GPU) : Jetson Orin Nano
• DeepStream Version : 7.1
• JetPack Version (valid for Jetson only) : 6.2
• TensorRT Version : 10.3.0.30
When I am running the deepstream python app, most of the time, it works fine, but some time, the FPS is showing 0 eventhough the RTSP stream is working fine,
Now playing...
1 : rtsp://192.168.20.104:8080/h264.sdp
Starting pipeline
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
Setting min object dimensions as 16x16 instead of 1x1 to support VIC compute mode.
WARNING: [TRT]: Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
0:00:00.798239996 631 0xaaaad86daf20 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/apps/deepstream-imagedata-multistream/yolov8n_320_15op_d.pt.onnx_b1_gpu0_fp16.engine
Implicit layer support has been deprecated
INFO: [Implicit Engine Info]: layers num: 0
0:00:00.798365788 631 0xaaaad86daf20 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-7.1/sources/deepstream_python_apps/apps/deepstream-imagedata-multistream/yolov8n_320_15op_d.pt.onnx_b1_gpu0_fp16.engine
0:00:00.805844797 631 0xaaaad86daf20 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:dstest_imagedata_config.txt sucessfully
Decodebin child added: source
(python3:631): GStreamer-WARNING **: 13:48:03.135: ../gst/gstpad.c:4677:gst_pad_push_data:<rtpsession0:sync_src> Got data flow before segment event
(python3:631): GStreamer-WARNING **: 13:48:03.135: ../gst/gstpad.c:4416:gst_pad_chain_data_unchecked:<rtpssrcdemux0:rtcp_sink> Got data flow before segment event
(python3:631): GStreamer-WARNING **: 13:48:03.137: ../gst/gstpad.c:4677:gst_pad_push_data:<rtpssrcdemux0:rtcp_src_2796152137> Got data flow before segment event
(python3:631): GStreamer-WARNING **: 13:48:03.137: ../gst/gstpad.c:4416:gst_pad_chain_data_unchecked:<rtpjitterbuffer0:sink_rtcp> Got data flow before segment event
Decodebin child added: decodebin0
Decodebin child added: rtph264depay0
Decodebin child added: h264parse0
Decodebin child added: capsfilter0
Decodebin child added: nvv4l2decoder0
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
**PERF: {'stream0': 0.0}
^CExiting app
[NvMultiObjectTracker] De-initialized
how to debug this issue, where is the issue for showing 0 FPS, it is not reading the frame,
thanks
