Jetson
• DeepStream Version
5.1
• TensorRT Version
7.1.3
We are using multifilesrc and JpegParser to process list of images in a folder
the issue with this pipeline is:
1- very slow compared to h264parser with video
on h264 parser the speed is 200 fps while the jpeg parser is 30 fps
2- pipeline with jpeg parser freezes when we set larger muxer width and height.
Is there best alternative for jpegparser we can use? is nvjpegdec will help us
I see this topic, but how can i inbtegrate this with our pipeline ?
* Copyright (c) 2019-2020, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <sys/time.h>
#include <glob.h>
#include "gstnvdsmeta.h"
#include <iostream>
#include <unistd.h>
#include <string>
#include <array>
#include <memory>
#include <boost/property_tree/ptree.hpp>
#include <boost/property_tree/xml_parser.hpp>
#include <boost/property_tree/ini_parser.hpp>
#include <boost/property_tree/json_parser.hpp>
using boost::property_tree::ptree;
using boost::property_tree::write_xml;
#include <vector>
#include <dirent.h>
#include <sys/types.h>
#include <string.h>
#include <list>
#include <iterator>
#include <cuda.h>
#include <cuda_runtime.h>
#include "nvbufsurface.h"
#include "nvbufsurftransform.h"
#include "opencv2/imgproc/imgproc.hpp"
#include "opencv2/highgui/highgui.hpp"
using namespace cv;
//#include <gtk/gtk.h>
//#include "gstnvstreammeta.h"
#ifndef PLATFORM_TEGRA
#include "gst-nvmessage.h"
#endif
#define MAX_DISPLAY_LEN 64
/* The muxer output resolution must be set if the input streams will be of
* different resolution. The muxer will scale all the input frames to this
* resolution. */
#define MUXER_OUTPUT_WIDTH 1920
#define MUXER_OUTPUT_HEIGHT 1080
using namespace std;
#define MAX_TRACKING_ID_LEN 16
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
* based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 40000
#define CONFIG_FILE_VW "config/config_vw_detection.txt"
#define TILED_OUTPUT_WIDTH 1920
#define TILED_OUTPUT_HEIGHT 1080
/* NVIDIA Decoder source pad memory feature. This feature signifies that source
* pads having this capability will push GstBuffers containing cuda buffers. */
#define GST_CAPS_FEATURES_NVMM "memory:NVMM"
#define FPS_PRINT_INTERVAL 300
/* tiler_sink_pad_buffer_probe will extract metadata received on OSD sink pad
* and update params for drawing rectangle, object information etc. */
static clock_t start_time = NULL;
static guint probe_counter = 0;
list<int> full_list;
int count_array = 0;
static int count = 0;
gint frame_number = 0;
int counter = 0;
#define CHECK_CUDA_STATUS(cuda_status, error_str) \
do \
if ((cuda_status) != cudaSuccess) \
g_print("Error: %s in %s at line %d (%s)\n", \
error_str, __FILE__, __LINE__, cudaGetErrorName(cuda_status)); \
} while (0)
static GstElement *
create_source_bin(guint index, gchar *uri)
GstElement *bin = NULL /*, *uri_decode_bin = NULL*/;
gchar bin_name[16] = {};
gboolean multi_file_src = FALSE;
g_snprintf(bin_name, 15, "source-bin-%02d", index);
/* Create a source GstBin to abstract this bin's content from the rest of the
* pipeline */
bin = gst_bin_new(bin_name);
GstElement *source, *jpegparser, *decoder;
if (strstr(uri, "%"))
std::cout << "multifilesrc"
<< "\n";
source = gst_element_factory_make("multifilesrc", "source");
multi_file_src = TRUE;
else
//std::cout << uri << "\n";
source = gst_element_factory_make("filesrc", "source");
jpegparser = gst_element_factory_make("jpegparse", "jpeg-parser");
decoder = gst_element_factory_make("nvv4l2decoder", "nvv4l2-decoder");
if (!source || !jpegparser || !decoder)
g_printerr("One element could not be created. Exiting.\n");
return NULL;
/* Set properties of the multifilesrc element */
GstCaps *caps =
gst_caps_new_simple("image/jpeg", "format", G_TYPE_STRING, "RGBA", "framerate", GST_TYPE_FRACTION, 1, 1, NULL);
//GstCapsFeatures *feature = gst_caps_features_new (GST_CAPS_FEATURES_NVMM, NULL);
//gst_caps_set_features (caps, 0, feature);
g_object_set(G_OBJECT(source), "location", uri, "caps", caps, NULL);
else
g_object_set(G_OBJECT(source), "location", uri, NULL);
const char *dot = strrchr(uri, '.');
if ((!strcmp(dot + 1, "mjpeg")) || (!strcmp(dot + 1, "mjpg")) || (multi_file_src == TRUE))
#ifdef PLATFORM_TEGRA
g_object_set(G_OBJECT(decoder), "mjpeg", 1, NULL);
#endif
gst_bin_add_many(GST_BIN(bin), source, jpegparser, decoder, NULL);
gst_element_link_many(source, jpegparser, decoder, NULL);
/* We need to create a ghost pad for the source bin which will act as a proxy
* for the video decoder src pad. The ghost pad will not have a target right
* now. Once the decode bin creates the video decoder and generates the
* cb_newpad callback, we will set the ghost pad target to the video decoder
* src pad. */
if (!gst_element_add_pad(bin, gst_ghost_pad_new_no_target("src",
GST_PAD_SRC)))
g_printerr("Failed to add ghost pad in source bin\n");
return NULL;
GstPad *srcpad = gst_element_get_static_pad(decoder, "src");
if (!srcpad)
g_printerr("Failed to get src pad of source bin. Exiting.\n");
return NULL;
GstPad *bin_ghost_pad = gst_element_get_static_pad(bin, "src");
if (!gst_ghost_pad_set_target(GST_GHOST_PAD(bin_ghost_pad),
srcpad))
g_printerr("Failed to link decoder src pad to source bin ghost pad\n");
return bin;
std::string exec(const char *cmd)
std::array<char, 128> buffer;
std::string result;
std::unique_ptr<FILE, decltype(&pclose)> pipe(popen(cmd, "r"), pclose);
if (!pipe)
throw std::runtime_error("popen() failed!");
while (fgets(buffer.data(), buffer.size(), pipe.get()) != nullptr)
result += buffer.data();
return result;
static GstPadProbeReturn
tiler_src_pad_buffer_probe(GstPad *pad, GstPadProbeInfo *info,
gpointer u_data)
g_print(" end of fraame \n");
counter++;
g_print("FRAME NUMBER ======================== %d \n", counter);
clock_t end_time = clock();
if (start_time == NULL)
start_time = end_time;
if ((((double)(end_time - start_time)) / CLOCKS_PER_SEC) > 1)
g_print("FPS ======================== %f \n", (probe_counter + 1) / 1.0);
g_print("prop counter ======================== %d \n", (probe_counter + 1));
full_list.push_back(probe_counter + 1);
probe_counter = 0;
else
probe_counter = probe_counter + 1;
#if 0
display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
NvOSD_TextParams *txt_params = &display_meta->text_params;
txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
/* Now set the offsets where the string should appear */
txt_params->x_offset = 10;
txt_params->y_offset = 12;
/* Font , font-color and font-size */
txt_params->font_params.font_name = "Serif";
txt_params->font_params.font_size = 10;
txt_params->font_params.font_color.red = 1.0;
txt_params->font_params.font_color.green = 1.0;
txt_params->font_params.font_color.blue = 1.0;
txt_params->font_params.font_color.alpha = 1.0;
/* Text background color */
txt_params->set_bg_clr = 1;
txt_params->text_bg_clr.red = 0.0;
txt_params->text_bg_clr.green = 0.0;
txt_params->text_bg_clr.blue = 0.0;
txt_params->text_bg_clr.alpha = 1.0;
nvds_add_display_meta_to_frame(frame_meta, display_meta);
#endif
return GST_PAD_PROBE_OK;
/* Tracker config parsing */
#define CHECK_ERROR(error) \
if (error) \
g_printerr("Error while parsing config file: %s\n", error->message); \
goto done; \
#define CONFIG_GROUP_TRACKER "tracker"
#define CONFIG_GROUP_TRACKER_WIDTH "tracker-width"
#define CONFIG_GROUP_TRACKER_HEIGHT "tracker-height"
#define CONFIG_GROUP_TRACKER_LL_CONFIG_FILE "ll-config-file"
#define CONFIG_GROUP_TRACKER_LL_LIB_FILE "ll-lib-file"
#define CONFIG_GROUP_TRACKER_ENABLE_BATCH_PROCESS "enable-batch-process"
#define CONFIG_GPU_ID "gpu-id"
static gchar *
get_absolute_file_path(gchar *cfg_file_path, gchar *file_path)
gchar abs_cfg_path[PATH_MAX + 1];
gchar *abs_file_path;
gchar *delim;
if (file_path && file_path[0] == '/')
return file_path;
if (!realpath(cfg_file_path, abs_cfg_path))
g_free(file_path);
return NULL;
// Return absolute path of config file if file_path is NULL.
if (!file_path)
abs_file_path = g_strdup(abs_cfg_path);
return abs_file_path;
delim = g_strrstr(abs_cfg_path, "/");
*(delim + 1) = '\0';
abs_file_path = g_strconcat(abs_cfg_path, file_path, NULL);
g_free(file_path);
static gboolean
bus_call(GstBus *bus, GstMessage *msg, gpointer data)
GMainLoop *loop = (GMainLoop *)data;
switch (GST_MESSAGE_TYPE(msg))
case GST_MESSAGE_EOS:
g_print("End of stream\n");
g_main_loop_quit(loop);
break;
case GST_MESSAGE_WARNING:
gchar *debug;
GError *error;
gst_message_parse_warning(msg, &error, &debug);
g_printerr("WARNING from element %s: %s\n",
GST_OBJECT_NAME(msg->src), error->message);
g_free(debug);
g_printerr("Warning: %s\n", error->message);
g_error_free(error);
break;
case GST_MESSAGE_ERROR:
gchar *debug;
GError *error;
gst_message_parse_error(msg, &error, &debug);
g_printerr("ERROR from element %s: %s\n",
if (debug)
g_printerr("Error details: %s\n", debug);
g_free(debug);
break;
case GST_MESSAGE_ELEMENT:
if (gst_nvmessage_is_stream_eos(msg))
guint stream_id;
if (gst_nvmessage_parse_stream_eos(msg, &stream_id))
g_print("Got EOS from stream %d\n", stream_id);
break;
#endif
default:
break;
return TRUE;
int main(int argc, char *argv[])
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *vw_detection = NULL,
*nvvidconv = NULL, *nvosd = NULL, *tiler = NULL, *mobile_v = NULL, *plate_detection = NULL, *vehicle_type = NULL, *plate_recognition = NULL, *dsexample = NULL, *nvtracker = NULL;
std::string input_path, input_format;
GstElement *transform = NULL;
#endif
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *tiler_src_pad = NULL;
guint i, num_sources;
guint tiler_rows, tiler_columns;
guint pgie_batch_size;
/* Check input arguments */
// if (argc < 2)
// g_printerr("Usage: %s <elementary JPEG file1> <elementary JPEG file2> ..."
// " <elementary JPEG fileN> \n",
// argv[0]);
// return -1;
// num_sources = argc - 1;
int width;
int height;
/* Standard GStreamer initialization */
gst_init(&argc, &argv);
loop = g_main_loop_new(NULL, FALSE);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new("P2P-pipeline");
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make("nvstreammux", "stream-muxer");
if (!pipeline || !streammux)
return -1;
gst_bin_add(GST_BIN(pipeline), streammux);
/* Read Settings file */
boost::property_tree::ptree settings;
read_ini("Settings/settings.ini", settings);
input_path = settings.get<std::string>("DEFAULT.INPUT_PATH");
//Input Preprocessing
gchar *image_folder = new char[input_path.length() + 1];
strcpy(image_folder, input_path.c_str());
chdir(image_folder);
char s[100];
printf("%s\n", getcwd(s, 100));
exec("mkdir tmp");
exec("curIdx=0; for curFile in *.jpg; do outFile=`printf \"./tmp/img_%04d.jpg\" \"$curIdx\"`; echo \'File: \'$curFile \'->\' $outFile; ln $curFile $outFile; curIdx=`expr $curIdx + 1 `; done");
chdir("/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/P2P_Engine_VW/");
input_path += "tmp/";
input_format = settings.get<std::string>("DEFAULT.INPUT_FORMAT");
/*Create full input Path */
std::string full_path_tmp = input_path + input_format;
gchar *image_file = new char[full_path_tmp.length() + 1];
strcpy(image_file, full_path_tmp.c_str());
GstPad *sinkpad, *srcpad;
gchar pad_name[16] = {};
GstElement *source_bin = create_source_bin(0, image_file);
if (!source_bin)
g_printerr("Failed to create source bin. Exiting.\n");
return -1;
gst_bin_add(GST_BIN(pipeline), source_bin);
g_snprintf(pad_name, 15, "sink_%u", i);
sinkpad = gst_element_get_request_pad(streammux, pad_name);
if (!sinkpad)
g_printerr("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad(source_bin, "src");
if (!srcpad)
return -1;
if (gst_pad_link(srcpad, sinkpad) != GST_PAD_LINK_OK)
g_printerr("Failed to link source bin to stream muxer. Exiting.\n");
return -1;
gst_object_unref(srcpad);
gst_object_unref(sinkpad);
num_sources = 8;
//nvtracker = gst_element_factory_make("nvtracker", "tracker");
//dsexample = gst_element_factory_make("dsexample", "example-plugin");
/* Use nvinfer to infer on batched frame. */
vw_detection = gst_element_factory_make("nvinfer", "primary-nvinference-engine");
//vehicle_type = gst_element_factory_make("nvinfer", "secondary2-nvinference-engine");
//plate_detection = gst_element_factory_make("nvinfer", "secondary1-nvinference-engine");
// plate_recognition = gst_element_factory_make("nvinfer", "secondary4-nvinference-engine");
/* Use nvtiler to composite the batched frames into a 2D tiled array based
* on the source of the frames. */
//tiler = gst_element_factory_make("nvmultistreamtiler", "nvtiler");
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make("nvvideoconvert", "nvvideo-converter");
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make("nvdsosd", "nv-onscreendisplay");
/* Finally render the osd output */
transform = gst_element_factory_make("queue", "nvegl-transform");
//transform = gst_element_factory_make("nvegltransform", "nvegl-transform");
#endif
sink = gst_element_factory_make("fakesink", "nvvideo-renderer");
if (!vw_detection || !nvvidconv || !sink)
return -1;
if (!transform)
g_printerr("One tegra element could not be created. Exiting.\n");
return -1;
#endif
g_object_set(G_OBJECT(streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", 1,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
/* Configure the nvinfer element using the nvinfer config file. */
g_object_set(G_OBJECT(vw_detection), "config-file-path", CONFIG_FILE_VW, NULL);
//g_object_set(G_OBJECT(plate_detection), "config-file-path", CONFIG_FILE_PLATE_DETECTION, NULL);
// g_object_set(G_OBJECT(vehicle_type), "config-file-path", CONFIG_FILE_VEHICLE_TYPE, NULL);
//g_object_set(G_OBJECT(dsexample), "full-frame", TRUE, NULL);
//g_object_get(G_OBJECT(dsexample), "processing-width", &width, NULL);
// g_object_get(G_OBJECT(dsexample), "processing-height", &height, NULL);
// g_object_set(G_OBJECT(plate_recognition), "config-file-path", CONFIG_FILE_PLATE_RECOGNITION, NULL);
std::cout << "batch size \n ";
/* Override the batch-size set in the config file with the number of sources. */
g_object_get(G_OBJECT(vw_detection), "batch-size", &pgie_batch_size, NULL);
if (pgie_batch_size != num_sources)
g_printerr("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
pgie_batch_size, num_sources);
g_object_set(G_OBJECT(vw_detection), "batch-size", 1, NULL);
std::cout << pgie_batch_size << " " << num_sources << endl;
/* we add a message handler */
bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
bus_watch_id = gst_bus_add_watch(bus, bus_call, loop);
gst_object_unref(bus);
/* Set up the pipeline */
/* we add all elements into the pipeline */
gst_bin_add_many(GST_BIN(pipeline), vw_detection, /*nvvidconv, /*nvosd,*/ transform, sink,
NULL);
#else
gst_bin_add_many(GST_BIN(pipeline), vw_detection, /*nvvidconv, nvosd,*/ sink,
NULL);
#endif
if (!gst_element_link_many(streammux, vw_detection, /* nvvidconv, /*nvosd, */ transform, sink, NULL))
g_printerr("Elements could not be linked. Exiting.\n");
return -1;
#else
if (!gst_element_link_many(streammux, vw_detection, /* nvvidconv, /*nvosd ,*/ sink, NULL))
return -1;
#endif
/* Lets add probe to get informed of the meta data generated, we add probe to
* the sink pad of the osd element, since by that time, the buffer would have
* had got all the metadata. */
tiler_src_pad = gst_element_get_static_pad(vw_detection, "src");
if (!tiler_src_pad)
g_print("Unable to get src pad\n");
else
gst_pad_add_probe(tiler_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
tiler_src_pad_buffer_probe, NULL, NULL);
/* Set the pipeline to "playing" state */
g_print("\n \n \n \n Now playing: \n \n \n \n ");
for (i = 0; i < num_sources; i++)
g_print(" %s,", argv[i + 1]);
g_print("\n");
gst_element_set_state(pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print("Running...\n");
const clock_t begin_time = clock();
g_main_loop_run(loop);
std::cout << float(begin_time);
int total = 0;
int c = 0;
list<int>::iterator it;
for (it = full_list.begin(); it != full_list.end(); ++it)
cout << '\t' << *it;
total = total + (*it);
c++;
g_print("******************* \n ");
g_print("count_array = %d\n", c);
g_print("sum = %d\n", total);
g_print("avg = %d\n", (total / c));
cout << '\n';
std::cout << float(clock() - begin_time) / CLOCKS_PER_SEC;
std::cout << "----------------------------" << endl;
std::cout << float(clock() - begin_time);
/* Out of the main loop, clean up nicely */
g_print("Returned, stopping playback\n");
gst_element_set_state(pipeline, GST_STATE_NULL);
g_print("Deleting pipeline\n");
gst_object_unref(GST_OBJECT(pipeline));
g_source_remove(bus_watch_id);
g_main_loop_unref(loop);
return 0;
