Hi
Is there a proper config file to run with deepstream 5.01 to get the highest performance on NX?
We tested NX real-time performance and got results below.
deepstream-app with 12 channels test result:
L4t r32.4.3 — got 28 fps
L4t r32.4.4 — got 30 fps
The performance is not close to the performance below.
The config file we used is “source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2.txt.”
Already set nvpmodel to 2 and enabled jetson clock.
Thank you for any advice,
