• Hardware Platform (GPU RTX 2080)
• DeepStream SDK 5.1
• TensorRT Version 7.2.2 + CUDA 11.2
• NVIDIA GPU Driver Version (460.32.03)
• Issue :could not decode and show the Bosch camera RTP source
Hi, every one, I am trying to use DeepStream to accelerate the decoding process of the RTP video source. I’ve made a simple pipeline to do decoing and show the video on the display:
gst-launch-1.0 -e udpsrc address=239.33.36.13 port=37004 caps = “application/x-rtp, media=(string)video,payload-type=(int)96, clock-rate=(int)90000, encoding-name=(string)H264” ! rtpjitterbuffer mode=4 ! rtph264depay ! h264parse ! nvv4l2decoder drop-frame-interval=1 ! nvvideoconvert ! video/x-raw, width=1080,height=720,format=NV12 ! nveglglessink window-x=0 window-y=0 window-width=1080 window-height=720
So the pipeline shown above with the source 239.33.36.13:37000 works well , the source is decoded and I could immediately see the it shown on the display. Then I changed the RTP source, which was taken from anthor Bosch camera:
gst-launch-1.0 -e udpsrc address=239.38.164.18 port=60160 caps = “application/x-rtp, media=(string)video,payload-type=(int)96, clock-rate=(int)90000, encoding-name=(string)H264” ! rtpjitterbuffer mode=4 ! rtph264depay ! h264parse ! nvv4l2decoder drop-frame-interval=1 ! nvvideoconvert ! video/x-raw, width=1080,height=720,format=NV12 ! nveglglessink window-x=0 window-y=0 window-width=1080 window-height=720
And this time the pipeline was stopped in the step “New clock: GstSystemClock”, I’ve also add a GST_DEBUG=3 at the head of my command, and I found some informations like:
0:00:02.961768115 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 1 Slice, Size: 199 will be dropped
0:00:03.002743235 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 6 SEI, Size: 88 will be dropped
0:00:03.002784101 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 1 Slice, Size: 1017 will be dropped
0:00:03.043630858 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 6 SEI, Size: 88 will be dropped
0:00:03.043671308 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 1 Slice, Size: 197 will be dropped
0:00:03.084440340 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 6 SEI, Size: 88 will be dropped
0:00:03.084482243 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 1 Slice, Size: 20 will be dropped
0:00:03.084502638 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 0 Unknown, Size: 70 will be dropped
0:00:03.084527020 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1310:gst_h264_parse_handle_frame: input stream is corrupt; it contains a NAL unit of length 0
0:00:03.084584268 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 5 Slice IDR, Size: 15 will be dropped
0:00:03.084634725 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 1 Slice, Size: 210 will be dropped
0:00:03.125247653 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 6 SEI, Size: 88 will be dropped
0:00:03.125289558 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 1 Slice, Size: 1023 will be dropped
0:00:03.166151911 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 6 SEI, Size: 88 will be dropped
0:00:03.166192843 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 1 Slice, Size: 179 will be dropped
0:00:03.207166903 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 6 SEI, Size: 88 will be dropped
0:00:03.207205099 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 1 Slice, Size: 231 will be dropped
0:00:03.248049068 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame: broken/invalid nal Type: 1 Slice, Size: 20 will be dropped
0:00:03.248106363 6538 0x55abd1a811e0 WARN h264parse gsth264parse.c:1310:gst_h264_parse_handle_frame: input stream is corrupt; it contains a NAL unit of length 0 (Final warning and then the pipeline was stopped…)
So as you see, I’ve changed nothing in the pipeline for the second RTP source, but it’s really strange that I could not get a poisitive response as the first one. I’ve also changed the decoded width or height but it didn’t work, so I doubt that maybe there’s sth different in the 2 RTP sources. The details of the 2 RTP source are as follows:
For the first source (which is rightly decoded and shown):
Input #0, sdp, from ‘239.33.36.13_37004.sdp’: Duration: N/A, start: 0.700000, bitrate: N/A
Stream #0:0: Video: h264 (High), yuv420p(tv, progressive), 1920x1080 [SAR 1:1 DAR 16:9], 15 fps, 30 tbr, 90k tbn, 30 tbc
[STREAM]
index=0
codec_name=h264
codec_long_name=H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
profile=High
codec_type=video
codec_time_base=1/30
codec_tag_string=[0][0][0][0]
codec_tag=0x0000
width=1920
height=1080
coded_width=1920
coded_height=1080
has_b_frames=0
sample_aspect_ratio=1:1
display_aspect_ratio=16:9
pix_fmt=yuv420p
level=40
color_range=tv
color_space=unknown
color_transfer=unknown
color_primaries=unknown
chroma_location=left
field_order=progressive
timecode=N/A
refs=1
is_avc=false
nal_length_size=0
id=N/A
r_frame_rate=30/1
avg_frame_rate=15/1
time_base=1/90000
start_pts=63000
start_time=0.700000
duration_ts=N/A
duration=N/A
bit_rate=N/A
max_bit_rate=N/A
bits_per_raw_sample=8
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
DISPOSITION:default=0
DISPOSITION:dub=0
DISPOSITION:original=0
DISPOSITION:comment=0
DISPOSITION:lyrics=0
DISPOSITION:karaoke=0
DISPOSITION:forced=0
DISPOSITION:hearing_impaired=0
DISPOSITION:visual_impaired=0
DISPOSITION:clean_effects=0
DISPOSITION:attached_pic=0
DISPOSITION:timed_thumbnails=0
[/STREAM]
[FORMAT]
filename=239.3.36.13_37004.sdp
nb_streams=1
nb_programs=0
format_name=sdp
format_long_name=SDP
start_time=0.700000
duration=N/A
size=125
bit_rate=N/A
probe_score=50
[/FORMAT]
For the seconde RTP source (which is taken from a camera Bosch and could not be decoded in DeepStream):
Input #0, sdp, from ‘239.38.164.18_60160.sdp’: Duration: N/A, start: 0.160000, bitrate: N/A
Stream #0:0: Video: h264 (Main), yuv420p(progressive), 512x288 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 180k tbc
[STREAM]
index=0
codec_name=h264
profile=Main
codec_type=video
codec_time_base=1/50
codec_tag=0x0000
width=512
height=288
coded_width=512
coded_height=288
has_b_frames=1
pix_fmt=yuv420p
level=30
color_range=unknown
color_space=unknown
timecode=N/A
refs=1
is_avc=false
nal_length_size=0
id=N/A
r_frame_rate=25/1
avg_frame_rate=25/1
time_base=1/90000
start_pts=14400
start_time=0.160000
duration_ts=N/A
duration=N/A
bit_rate=N/A
max_bit_rate=N/A
nb_frames=N/A
nb_read_frames=N/A
nb_read_packets=N/A
DISPOSITION:dub=0
[/STREAM]
[FORMAT]
filename=239.38.164.18_60160.sdp
nb_streams=1
nb_programs=0
format_name=sdp
start_time=0.160000
duration=N/A
size=125
bit_rate=N/A
probe_score=50
[/FORMAT]
As you can see, there’s some difference between the parameters of these 2 source. Actually I don’t kown very well the format of the video, so could someone tell me if this decoding problme is caused by some strange parameters in the second source, or should I modify my pipeline to adapt it? Thanks in advance!
