Deepstream RTP protocol
Hardware Platform (Jetson / GPU) : NVIDIA A2
• DeepStream Version : 6.3
• TensorRT Version : 12.2
• NVIDIA GPU Driver Version (valid for GPU only) : 535.146.02
regarding below link parameter select-rtp-protocol has two values
0 UDP + UDP Multicast + TCP
4 TCP Only
does this mean if I set this parameter in nvurisrcbin element , this means pipeline use RTP not RTSP or it uses RTP with RTSP
Camera model: DH-IPC-HFW5442EPZE - 4MP
https://docs.nvidia.com/metropolis/deepstream-nvaie31/dev-guide/text/DS_plugin_gst-nvurisrcbin.html
Appreciate more clarification in this point
It means whether the transport layer protocol is tcp or udp.
i need more clarification select-rtp-protocol does this mean deepstream pipeline use RTP and RTSP protocols?
Please refer to the Gstreamer Guide below: protocols.
thanks
