Deepstream RTSP out over IPv6
Setup :
• Jetson Nano
• Deepstream 6.0
• Jetpack 4.6.2
• used deepstream_app
I’m trying to publish rtsp stream over IPv6 using deepstream_app.
It working fine in my IPv4 network but not in IPv6
I can use IPv6 for RTSP in and I can ping the jetson over IPv6 network
I tried to change default gstreamer multicast ipv4 adress “224.224.255.255” to different multicast IPv6 adress (link-local, global multicast,…) but none of them worked.
Can you tell me if it is possible to use IPv6 RTSP out with deepstream ?
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
It is possible. Please refer to gstreamer community.
gst-rtsp-server/rtsp-stream.c at master · thaytan/gst-rtsp-server (github.com)
What is the correct IPv6 setting for Gstreamer UDPSINK Clients? - Stack Overflow
