Deepstream RTSP reading fails with type=4 but works with multiURI
Deepstream test5app fails when i use type 4 in source plugin for reading RTSP
Failing config:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://ip:port/stream.mjpeg
num-sources=1
gpu-id=0
Working Config
[source0]
enable=1
type=3
num-sources=1
gpu-id=0
deepstream version: deepstream4.0
GPU: Geforce GTX 1060
The failing config fails with:
src_elem0:internal data stream error error
Working config prints the following to terminal even if no logs are enabled:
YUV 4:2:0 chroma subsampling
NvJPEG decode complete
size set = 64
For RTSP source , we support H264 or H265 stream parsing, for mjpeg stream, you can use URI or MultiURI source type.
Regarding the logs that get printed on the screen. Can we disable them?
It’s gstreamer logging mechanism, you can not disable it. it’s error information that can help identify where get wrong
