Hardware Platform (Jetson / GPU)
- AGX Xavier [16GB]
DeepStream Version - deepstream 5.0
JetPack Version (valid for Jetson only) - 4.4 [L4T 32.4.3]
TensorRT Version - 7.1.3.0
Hello.
I need to run deepstream on php.
I run deepstream with linux shell script and php is uses it.
shell_exec(“./deepstream.sh”);
and this is my shell script (deepstream.sh)
#!/bin/bash
cd …/…/deepstream/apps/sample_apps/deepstream-app
./deepstream-app -c config/rtsp_analytics_video.txt
There’s error while running the deepstream shell script with php.
However, there are no errors while running the deepstream shell script with the Linux terminal command
nvbufsurftransform:cuInit failed : 100
2020-12-03 11:47:24.338761: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.2
2020-12-03 11:47:24.792535: I tensorflow/stream_executor/platform/default/dso_loader.cc:48] Successfully opened dynamic library libcudart.so.10.2
Error: Can’t initialize nvrm channel
Couldn’t create ddkvic Session: Cannot allocate memory
nvbuf_utils: Could not create Default NvBufferSession
** ERROR: <create_multi_source_bin:1057>: Failed to create element ‘src_bin_muxer’
** ERROR: <create_multi_source_bin:1132>: create_multi_source_bin failed
** ERROR: <create_pipeline:1296>: create_pipeline failed
** ERROR: main:636: Failed to create pipeline
Quitting
App run failed
Please check my erorr msg.
How can I solve this issue?
