DeepStream sample configs
I’m trying to run the deepstream-app command using the following:
deepstream-app -c source4_720p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
But then I get this output and it fails. I’m trying to output the results to an mp4. Here’s my config:
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=5
flow-original-resolution=1
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=1
rows=2
columns=2
width=1280
height=720
gpu-id=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
uri=file://../../streams/sample_720p.mp4
num-sources=4
gpu-id=0
[sink0]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
[sink1]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
## only SW mpeg4 is supported right now.
codec=3
sync=0
bitrate=2000000
output-file=out.mp4
source-id=0
[osd]
enable=1
gpu-id=0
osd-mode=1
border-width=1
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
show-clock=0
clock-x-offset=800
clock-y-offset=820
clock-text-size=12
clock-color=1;0;0;0
[primary-gie]
enable=1
gpu-id=0
net-scale-factor=0.0039215697906911373
model-file=../../models/Primary_Detector/resnet10.caffemodel
proto-file=../../models/Primary_Detector/resnet10.prototxt
model-cache=../../models/Primary_Detector/resnet10.caffemodel_b4_int8.cache
labelfile-path=../../models/Primary_Detector/labels.txt
int8-calib-file=../../models/Primary_Detector/cal_trt4.bin
net-stride=16
batch-size=4
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
num-classes=4
class-thresholds=0.2;0.2;0.1;0.2
class-eps=0.2;0.2;0.2;0.2
class-group-thresholds=1;1;1;1
roi-top-offset=0;0;0;0
roi-bottom-offset=0;0;0;0
detected-min-w=0;0;0;0
detected-min-h=0;0;0;0
detected-max-w=1280;1280;1280;1280
detected-max-h=720;720;720;720
interval=0
gie-unique-id=1
parse-func=4
output-bbox-name=conv2d_bbox
output-blob-names=conv2d_cov
parser-bbox-norm=35.0;35.0
#config-file=config_infer_resnet.txt
[tracker]
enable=1
tracker-width=640
tracker-height=368
gpu-id=0
[secondary-gie0]
enable=1
net-scale-factor=1
model-file=../../models/Secondary_VehicleTypes/resnet18.caffemodel
proto-file=../../models/Secondary_VehicleTypes/resnet18.prototxt
model-cache=../../models/Secondary_VehicleTypes/resnet18.caffemodel_b16_int8.cache
mean-file=../../models/Secondary_VehicleTypes/mean.ppm
labelfile-path=../../models/Secondary_VehicleTypes/labels.txt
int8-calib-file=../../models/Secondary_VehicleTypes/cal_trt4.bin
gpu-id=0
batch-size=16
num-classes=6
network-mode=1
detected-min-w=128
detected-min-h=128
detected-max-w=1280
detected-max-h=720
model-color-format=1
gie-unique-id=4
operate-on-gie-id=1
operate-on-class-ids=0;
is-classifier=1
output-blob-names=predictions/Softmax
classifier-async-mode=1
classifier-threshold=0.51
[secondary-gie1]
enable=1
net-scale-factor=1
model-file=../../models/Secondary_CarColor/resnet18.caffemodel
proto-file=../../models/Secondary_CarColor/resnet18.prototxt
model-cache=../../models/Secondary_CarColor/resnet18.caffemodel_b16_int8.cache
mean-file=../../models/Secondary_CarColor/mean.ppm
labelfile-path=../../models/Secondary_CarColor/labels.txt
batch-size=16
network-mode=1
detected-min-w=128
detected-min-h=128
detected-max-w=1280
detected-max-h=720
num-classes=12
gpu-id=0
gie-unique-id=5
operate-on-gie-id=1
is-classifier=1
[secondary-gie2]
enable=1
net-scale-factor=1
model-file=../../models/Secondary_CarMake/resnet18.caffemodel
proto-file=../../models/Secondary_CarMake/resnet18.prototxt
model-cache=../../models/Secondary_CarMake/resnet18.caffemodel_b16_int8.cache
mean-file=../../models/Secondary_CarMake/mean.ppm
labelfile-path=../../models/Secondary_CarMake/labels.txt
int8-calib-file=../../models/Secondary_CarMake/cal_trt4.bin
batch-size=16
network-mode=1
num-classes=24
detected-min-w=128
detected-min-h=128
detected-max-w=1280
detected-max-h=720
gpu-id=0
gie-unique-id=6
operate-on-gie-id=1
is-classifier=1
[tests]
file-loop=0
Any suggestions on what I might be doing wrong?
Here’s the output:
nvstreamtiler: batchSize set as 4
Conversion not supported... gst_nvvidconv_planar_to_planar_conversion, 720
Error from qtdemux3: GStreamer encountered a general stream error.
Debug info: qtdemux.c(5520): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin0/GstQTDemux:qtdemux3:
streaming stopped, reason not-supported
Error from qtdemux2: GStreamer encountered a general stream error.
Debug info: qtdemux.c(5520): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin3/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin3/GstQTDemux:qtdemux2:
Error from qtdemux0: GStreamer encountered a general stream error.
Debug info: qtdemux.c(5520): gst_qtdemux_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin2/GstURIDecodeBin:src_elem/GstDecodeBin:decodebin2/GstQTDemux:qtdemux0:
Quitting
App run failed
Your input argument of source0 is incompatible.
[source0]
enable=1
type=3
num-sources=4
gpu-id=0
If you have four num-sources, please enter four uri information.
Otherwise, please update num-sources to one.
Hi AastaLLL,
I am running the same demo.I can run it successfully.
But I want to know:
1,If I have four num-sources.How to “enter four uri information”?
2,If I want to use a USB camera to run this demo.Is that OK? What else do I need to do besides change “type=1”?
thank you for any help.
