I am trying to run deepstream sdk 4.0 samples - deepstream-app on Jetson TX2 (flashed with JetPack 4.2.1) using RTSP streams. I have been successful in running v4l2 camera stream with deepstream-app. However, I have been able to achieve success with RTSP streams, but run too slow.
Following are the changes made in the config file for running deepstream-app:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=1
camera-width=640
camera-height=480
camera-fps-n=30
camera-v4l2-dev-node=1
uri=file://../../streams/sample_1080p_h264.mp4
#uri=rtsp://admin:abc.0714@169.254.5.64:554/h264/main/ch1/main/av_stream
num-sources=12
#drop-frame-interval=2
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=1
source-id=0
gpu-id=0
qos=0
nvbuf-memory-type=0
overlay-id=1
[sink2]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming
type=4
#1=h264 2=h265
codec=1
sync=0
bitrate=4000000
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
when running this code:
deepstream-app -c /home/nvidia/xiongqf/software/deepstream_sdk_v4.0_jetson/samples/configs/deepstream-app/source12_1080p_dec_infer-resnet_tracker_tiled_display_fp16_tx2.txt
I am able to access the RTSP stream using the following gstreamer command.
gst-launch-1.0 rtspsrc latency=1 location=rtsp://127.0.0.1:8554/ds-test ! rtph264depay ! h264parse ! omxh264dec ! nveglglessink -e
At last, we got the result as follows:
Additional debug info:
gstbasesink.c(2902): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
There may be a timestamping problem, or this computer is too slow.
