Deepstream SDK 5.1 objectDetector_SSD compilation error
• Hardware Platform (GPU)
• DeepStream Version 5.1
• TensorRT Version 8.0
• NVIDIA GPU Driver Version (465.19.01)
I am new to Deepstream, and when I try to compile the sample detector SSD as the README instruction:
& cd /opt/nvidia/deepstream/deepstream/sources/object_Detector_SSD/nvdsinfer_custom_impl_ssd
& make
Then I found the following errors:
375 | nvcaffeparser1::IPluginFactory *pluginFactory;
| IPluginFactoryV2
…/…/includes/nvdsinfer_custom_impl.h:376:19: error: ‘IPluginFactoryExt’ in namespace ‘nvcaffeparser1’ does not name a type; did you mean ‘IPluginFactoryV2’?
376 | nvcaffeparser1::IPluginFactoryExt *pluginFactoryExt;
| IPluginFactoryV2
…/…/includes/nvdsinfer_custom_impl.h:386:16: error: ‘IPluginFactory’ in namespace ‘nvuffparser’ does not name a type
386 | nvuffparser::IPluginFactory pluginFactory;
…/…/includes/nvdsinfer_custom_impl.h:387:16: error: ‘IPluginFactoryExt’ in namespace ‘nvuffparser’ does not name a type
387 | nvuffparser::IPluginFactoryExt pluginFactoryExt;
nvdsiplugin_ssd.cpp:91:9: error: looser throw specifier for ‘virtual int FlattenConcat::getNbOutputs() const’
91 | int getNbOutputs() const override { return 1; }
In file included from /usr/include/x86_64-linux-gnu/NvInferLegacyDims.h:53,
from /usr/include/x86_64-linux-gnu/NvInfer.h:53,
from /usr/include/x86_64-linux-gnu/NvInferPlugin.h:53,
from nvdsiplugin_ssd.cpp:23:
/usr/include/x86_64-linux-gnu/NvInferRuntimeCommon.h:442:21: note: overridden function is ‘virtual int32_t nvinfer1::IPluginV2::getNbOutputs() const noexcept’
442 | virtual int32_t getNbOutputs() const noexcept = 0;
nvdsiplugin_ssd.cpp:93:10: error: looser throw specifier for ‘virtual nvinfer1::Dims FlattenConcat::getOutputDimensions(int, const Dims
, int)’
93 | Dims getOutputDimensions(int index, const Dims
inputs, int nbInputDims) override
Could anyone give me some instruction?
Did you use TRT 8.0? you should use 7.2.2 for deepstream 5.1
Thanks for your reply. Actually my ubuntu version is 20.04, and I observed that TRT7.2.2 just supports to Ubuntu 18.04. Should I stil install 7.2.2 on my ubuntu 20.04? Or is there any other solution that can fixes this problem ?
You can use docker to avoid this.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_docker_containers.html
Really thanks!
