• Hardware Platform (Jetson / GPU): Jetson
• DeepStream Version: 8.0
• JetPack Version (valid for Jetson only): 7.0
• TensorRT Version: 10.14.1
• Issue Type( questions, new requirements, bugs): questions
I developed an object detection programme with nvinfer on the Jetson AGX Orin with DeepStream SDK 7.1.
I want to use Jetson Thor, so I updated to DeepStream SDK 8.0 and ran the programme, but the model only output NaN.
Upon investigation, I found that this bug can be reproduced when network-mode=2(FP16) is specified.
Furthermore, I found that the convolution layer in the model was outputting NaN values.
As both of the above results relate to TensorRT features, we considered that upgrading TensorRT from version 10.3.0 to 10.13.2 was the cause of the bug.
Additionally, as the DeepStream SDK 9.0 also uses TensorRT 10.13.2, upgrading the DeepStream SDK is considered ineffective.
I tried updating TensorRT to versions 10.13.3 and 10.14.1, and found that after updating to 10.14.1, it worked correctly with network-mode=2.
I also plan to use features of the DeepStream SDK other than nvinfer.
If I update TensorRT from version 10.13.2 to 10.14.1, will I still be able to use the DeepStream SDK’s features?
