36.[DSx_All_App] How to use Nsight System CLI to profile DeepStream App from the command line.
Deepstream Plugins that can be queried using this tool.
| Plugins | Tags |
| nvv4l2-decoder | Call to NV12_to_NV12_cutex Call to cudaEventCreateWithFlags …… |
| nvstreammux | stream-muxer_acquireBufferFromPool(Batch=0) stream-muxer_collectingBuffers(Batch=0) … |
| nvinfer | buffer_process batch_num=1 …… |
| nvinferserver | buffer_process batch_num=1 … |
| nvdewarper | nvdewarper0_(Frame=1)_Scale …… |
| nvdsosd | nv-onscreendisplay_(Frame=0) … |
| nvmultistreamtiler | tiled_display_tiler_(Frame=0) …… |
| nvtracker | (null)_nvtracker_convert_buffer(Frame=0) …… |
How to use the tool(Take the deepstream-test1 as an example.)
Make sure you have the Nsight System installed on your system. You can download and install it from the following page Nsight Systems - Get Started | NVIDIA Developer according to your platform.
Use NVTX to trace any CUDA kernal function wrote by yourself if necessary.
- Add
#include “nvtx3/nvToolsExt.h” in the source code. - Add the compiler flag “-ldl” in the Makefile
- Add calls to the NVTX API functions below.
nvtxRangePush("my_cuda_kernal");
//your code
nvtxRangePop();
- Run the command below, it will generate a report file called nsys_report.nsys-rep
$nsys profile -w true -t "cuda,cudnn,osrt,nvtx" -o ./nsys_report --cuda-memory-usage=true ./deepstream-test1-app dstest1_config.yml
- Use the Nsight Systems App to read the nsys_report on your Microsoft System. As the image below, just right click the GstNvinfer and choose the “Show in Events View”, the detailed information is displayed at the bottom.
