44. [DSx_All_App] How to extract specific class on deepstream with nvinferserver
diff --git a/sources/gst-plugins/gst-nvinferserver/gstnvinferserver_meta_utils.cpp b/sources/gst-plugins/gst-nvinferserver/gstnvinferserver_meta_utils.cpp
index d13a005..39c7336 100755
--- a/sources/gst-plugins/gst-nvinferserver/gstnvinferserver_meta_utils.cpp
+++ b/sources/gst-plugins/gst-nvinferserver/gstnvinferserver_meta_utils.cpp
@@ -105,6 +105,11 @@ attachDetectionMetadata(
+ const auto& ids = config.output_control().filter_out_class_ids();
+ if (!ids.empty() &&
+ (std::find(ids.begin(), ids.end(), obj.classIndex) != ids.end()))
+ continue;
/* Scale the bounding boxes proportionally based on how the object/frame
* was scaled during input. */
obj.left = (obj.left - offsetLeft) / scaleX + roiLeft;
diff --git a/sources/gst-plugins/gst-nvinferserver/nvdsinferserver_plugin.proto b/sources/gst-plugins/gst-nvinferserver/nvdsinferserver_plugin.proto
index 3d39caf..3843ec8 100755
--- a/sources/gst-plugins/gst-nvinferserver/nvdsinferserver_plugin.proto
+++ b/sources/gst-plugins/gst-nvinferserver/nvdsinferserver_plugin.proto
@@ -124,6 +124,8 @@ message PluginControl {
/* Classifier type of a particular nvinferserver component. */
string classifier_type = 3;
+ /* Filter specified class IDs */
+ repeated int32 filter_out_class_ids = 4;
# /opt/nvidia/deepstream/deepstream/sources/includes/nvdsinferserver_plugin.proto also needs to be modified
make CUDA_VER=xxx install
Finally, add this to your application configuration file
output_control {
filter_out_class_ids: [1, 2, 3]
