• Hardware Platform (Jetson / GPU): Jetson Orin
• DeepStream Version: 7.1
• JetPack Version (valid for Jetson only): Unknown
• TensorRT Version: Unknown
• Issue Type( questions, new requirements, bugs): Question re: EULA
• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing): N/A
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description): N/A
We’d like to discuss with NVIDIA use of DeepStream (v7.1) in an autonomous vehicle application, per the DeepStream SDK license this use requires a separate agreement:
2.6 Unless you have an agreement with NVIDIA for this purpose, you may not use the SDK with any system or application
where the use or failure of the system or application can reasonably be expected to threaten or result in personal injury,
death, or catastrophic loss. Examples include use in nuclear, avionics, navigation, military, medical, life support or other life
critical applications. NVIDIA does not design, test or manufacture the SDK for these critical uses and NVIDIA shall not be liable
to you or any third party, in whole or in part, for any claims or damages arising from such uses.```
Thank you,
Gash
