About the link timeout issue of python3 deepstream-test3 demo
Deep stream has been stuck
Deep stream
Decoder sub add: source
Add decoder sub-item: typefindelement0
The program will be terminated after waiting a long time, and it will prompt Error: gst-resource-error-quark: Could not read from resource. (9): gstrtmpsrc.c(419): gst_rtmp_src_create (): /GstPipeline:pipeline0/GstBin :source-bin-01/GstURIDecodeBin:uri-decode-bin/GstRTMPSrc:source:
Failed to read any data from stream, check your URL
Exiting app
How do I set the network link timeout time? The python I use is used in test3 of deepstream-app
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
No, I am a multi-format stream input. Although it is rtmp, the streaming media format I input is multiple,I want to know how to set the timeout in the previous element of uridecodebin
